Home » Eclipse Projects » Sirius » edge between elements in an ordered set
edge between elements in an ordered set [message #1793472] Wed, 08 August 2018 15:30 Go to next message
I have instances of type X, which are represented as a square node.
I have an ordered set of X.
I would like to create and edge between each consecutive instances of X in the ordered set.
Is there any way to do that ? I tried but without success...
thanks in advance
Re: edge between elements in an ordered set [message #1793564 is a reply to message #1793472] Fri, 10 August 2018 04:59 Go to previous messageGo to next message
you should be able to do that by using a Relation Based Edge and then using a query with "siblings" to retrieve the target element. Something like "aql:self.followingSiblings()->first()"
You might want to restrict to a specific feature using a query similar to this one (used in the case of the eClassifiers containment reference): "aql:self.followingSiblings()->select( s | s.eContainingFeature().name = 'eClassifiers')->first()"
Re: edge between elements in an ordered set [message #1793566 is a reply to message #1793472] Fri, 10 August 2018 05:35 Go to previous messageGo to next message
Dear Julien,
To do this, you should use a Relation Based Edge.
In the Target Finder Expression you should use a Java service to retrieve the consecutives instances of X.
Re: edge between elements in an ordered set [message #1793571 is a reply to message #1793566] Fri, 10 August 2018 07:06 Go to previous message
I tried the proposition of Cedric and it works like a charm !
Thanks a lot to both of you !
j
Previous Topic:Delete multiple elements that are selected by using Java Service
Next Topic:Overriding default layer tools in extension viewpoint
Current Time: Sun Aug 31 11:13:16 EDT 2025
Powered by FUDForum. Page generated in 0.03499 seconds
