Home » Eclipse Projects » P2 » Cannot open Eclipse Marketplace(Cannot open Eclipse Marketplace)
Cannot open Eclipse Marketplace [message #1793409] Tue, 07 August 2018 13:30 Go to next message
getting below error when i open Eclipse Marketplace .
am using proxy. able to access internet Windows->ShowView->Internal Web Browser.
Eclipse version : kepler
!ENTRY org.eclipse.epp.mpc.ui 4 0 2018-08-01 09:19:07.968
!MESSAGE Cannot open Eclipse Marketplace
!STACK 1
org.eclipse.core.runtime.CoreException: Cannot install remote marketplace locations: Unable to read repository at http://marketplace.eclipse.org/catalogs/api/p.
at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCommand.execute(MarketplaceWizardCommand.java:101)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4166)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1489)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1474)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4012)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Caused by: org.eclipse.core.runtime.CoreException: Unable to read repository at http://marketplace.eclipse.org/catalogs/api/p.
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.stream(RepositoryTransport.java:181)
at org.eclipse.epp.internal.mpc.core.util.AbstractP2TransportFactory.invokeStream(AbstractP2TransportFactory.java:35)
at org.eclipse.epp.internal.mpc.core.util.TransportFactory$1.stream(TransportFactory.java:69)
at org.eclipse.epp.internal.mpc.core.service.RemoteMarketplaceService.processRequest(RemoteMarketplaceService.java:131)
at org.eclipse.epp.internal.mpc.core.service.RemoteMarketplaceService.processRequest(RemoteMarketplaceService.java:85)
at org.eclipse.epp.internal.mpc.core.service.RemoteMarketplaceService.processRequest(RemoteMarketplaceService.java:72)
at org.eclipse.epp.internal.mpc.core.service.DefaultCatalogService.listCatalogs(DefaultCatalogService.java:36)
at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCommand$5.run(MarketplaceWizardCommand.java:254)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
at com.sun.security.ntlm.Client.type3(Client.java:161)
at sun.net.www.protocol.http.ntlm.NTLMAuthentication.buildType3Msg(NTLMAuthentication.java:250)
at sun.net.www.protocol.http.ntlm.NTLMAuthentication.setHeaders(NTLMAuthentication.java:225)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1661)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492)
at org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnectionRetrieveFileTransfer.getDecompressedStream(UrlConnectionRetrieveFileTransfer.java:542)
at org.eclipse.ecf.provider.filetransfer.retrieve.UrlConnectionRetrieveFileTransfer.openStreams(UrlConnectionRetrieveFileTransfer.java:312)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:879)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:570)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:422)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.read(FileReader.java:273)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.stream(RepositoryTransport.java:172)
... 12 more
Thanks and Regards.
Raj
Re: Cannot open Eclipse Marketplace [message #1793545 is a reply to message #1793409] Thu, 09 August 2018 21:01 Go to previous messageGo to next message
me too
Re: Cannot open Eclipse Marketplace [message #1793546 is a reply to message #1793545] Thu, 09 August 2018 22:05 Go to previous messageGo to next message
Both are the result of not finding a repository when we should!
!STACK 1
The Part in big red is the indicator of the problem!!!!
-jeff
I can dignose what is the indicator, in my case EVERY attempt to use the Marketplace ends too soon with that error!!!
-jeff
Re: Cannot open Eclipse Marketplace [message #1793547 is a reply to message #1793545] Thu, 09 August 2018 22:05 Go to previous messageGo to next message
!STACK 1
-jeff
-jeff
Re: Cannot open Eclipse Marketplace [message #1793548 is a reply to message #1793545] Thu, 09 August 2018 22:05 Go to previous messageGo to next message
!STACK 1
-jeff
-jeff
Re: Cannot open Eclipse Marketplace [message #1793549 is a reply to message #1793545] Thu, 09 August 2018 22:05 Go to previous messageGo to next message
!STACK 1
-jeff
-jeff
Re: Cannot open Eclipse Marketplace [message #1793550 is a reply to message #1793545] Thu, 09 August 2018 22:05 Go to previous messageGo to next message
!STACK 1
-jeff
-jeff
Re: Cannot open Eclipse Marketplace [message #1793551 is a reply to message #1793545] Thu, 09 August 2018 22:06 Go to previous messageGo to next message
!STACK 1
-jeff
-jeff
Re: Cannot open Eclipse Marketplace [message #1793552 is a reply to message #1793551] Thu, 09 August 2018 22:27 Go to previous message
SO Sorry!
-jeff
Moderator please clean the multiple posts above that are duplicate.
Previous Topic:Download eclipse plugins from update site with out eclipse command line
Next Topic:How to trigger multiple changes via different p2.inf files in eclipse?
Current Time: Sun Jul 20 21:17:27 EDT 2025
Powered by FUDForum. Page generated in 1.58356 seconds
