Home » Modeling » Eclipse Layout Kernel » Is there a standard ELK Graph View, that understands ELK Graph and knows how to show it?(A standard implementation of the ELK Graph View)
| Is there a standard ELK Graph View, that understands ELK Graph and knows how to show it? [message #1792819] |
Tue, 24 July 2018 08:17  |
I have a situation, where I have an instance of the domain model and I would like to show it in a view.
I do not need an editor - only a view.
Furthermore, ELK Graph data type completely covers the domain model I am working with. Thus I could image the following:
my domain model ==> ELK Graph (a call to layout happens here) ==> ELK graph is shown in a "ELK Graph view".
If there is such "ELK Graph view", could you please, point to an example/test case, that uses it? I could not find one myself in your documentation.
Mindaugas Laganeckas
| Re: Is there a standard ELK Graph View, that understands ELK Graph and knows how to show it? [message #1793069 is a reply to message #1792838] |
Mon, 30 July 2018 09:49   |
Thank you both for the answers.
I have a few comments:
1. I knew about KLightD framework beforehand, but it was not clear to me, that KLightD and ELK are integrated. I did not want to waste my time with KGraph and possibly outdated KLightD. Could the owners/responsible people write in their website, that KLightD and ELK are integrated? That could definitely save your time. :)
2. The bleeding edge ELK (v0.5) and the latest KLightD are no longer compatible due to the fact, that a class has been moved to another package in ELK and the same class is used by KLightD. I fixed the import problem locally, but is there an integration job, that would make sure ELK and KLightD are aligned? I guess KLightD should be updated every time backwards incompatible change is made.
3. The examples in the KLightD are no longer available. Is there an easy way to get read access to the KLightD git repository? I have checked their webpage, but I was not sure if everyone can checkout the KLightD code.
Christoph and Ulf, feel free to forward my questions/comments to the KLightD project without using too much time for answering them. :)
Best,
Mindaugas
| Re: Is there a standard ELK Graph View, that understands ELK Graph and knows how to show it? [message #1793075 is a reply to message #1793069] |
Mon, 30 July 2018 10:19  |
Mindaugas Laganeckas wrote on Mon, 30 July 2018 13:49Thank you both for the answers.
Most welcome. :)
Mindaugas Laganeckas wrote on Mon, 30 July 2018 13:491. I knew about KLightD framework beforehand, but it was not clear to me, that KLightD and ELK are integrated. I did not want to waste my time with KGraph and possibly outdated KLightD. Could the owners/responsible people write in their website, that KLightD and ELK are integrated? That could definitely save your time. :)
Good idea, will do. What do you consider KLighD's website? Its Confluence Wiki page?
Mindaugas Laganeckas wrote on Mon, 30 July 2018 13:492. The bleeding edge ELK (v0.5) and the latest KLightD are no longer compatible due to the fact, that a class has been moved to another package in ELK and the same class is used by KLightD. I fixed the import problem locally, but is there an integration job, that would make sure ELK and KLightD are aligned? I guess KLightD should be updated every time backwards incompatible change is made.
I already fixed that. The problem persisted as long as it did because we had massive problems with the nightly ELK build. That caused the nightly KLighD build to fail, since that was already adapted to the class's new package.
In general, we see integration problems due to our nightly builds.
Mindaugas Laganeckas wrote on Mon, 30 July 2018 13:493. The examples in the KLightD are no longer available. Is there an easy way to get read access to the KLightD git repository? I have checked their webpage, but I was not sure if everyone can checkout the KLightD code.
Yes, KLighD is part of the KIELER Pragmatics project, whose [url=https://git.rtsys.informatik.uni-kiel.de/projects/KIELER/repos/pragmatics/browse]repository[/quote] can be cloned anonymously. You can find example projects based on KLighD as part of the OpenKieler project. Look at KlassViz, DebuKViz, and EcoreViz, for example.
Mindaugas Laganeckas wrote on Mon, 30 July 2018 13:49Christoph and Ulf, feel free to forward my questions/comments to the KLightD project without using too much time for answering them. :)
Well, KLighD is developed here at Kiel University where I still work, so I may as well answer your questions. ;) At some point we might want to move the discussion over away from the ELK forums.
Chris
Current Time: Sun Nov 09 06:07:47 EST 2025
Powered by FUDForum. Page generated in 0.12490 seconds
