Home » Modeling » TMF (Xtext) » Whitespace without newlines
Whitespace without newlines [message #1059120] Thu, 16 May 2013 16:23 Go to next message
Hello Xtext enthusiasts,
My language has some whitespace-sensitive aspects with newlines which have forced me to implement the whitespace rule like this with only spaces and tabs:
terminal WS:
	(' '|'\t')+;
Throughout the rest of my grammar I look for one of three possible alternatives that end in a newline character. I created a datatype rule for an end-of-line (EOL).
EOL:
	SL_COMMENT | LINEWRAP | NEWLINE;
terminal LINEWRAP:
	('\\' '\r'? '\n');
terminal SL_COMMENT:
	'//' !('\r'|'\n')* ('\r'? '\n');
terminal NEWLINE:
	('\r'? '\n');
I hide my whitespace rule throughout the grammar, so all spaces and tabs are hidden. A simplified example of this is as follows:
grammar XXXXX
hidden(WS)
generate wirelist "http://XXXX/Wirelist"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model: {Model}
	(blocks+=Block)* EOL*;
Block:
	EOL*
	(	Block1
	|	Block2
Block1:
	'BLOCK1' EOL* 'BEGIN' EOL*
		('PARAM1' ',' p1val1=ID',' p1val2=Number ',' p1val3=ID EOL+) &
		('PARAM2' ',' p2val1=ID EOL+) &
		('PARAM3' ',' p3val1=ID EOL+)
	) 'END';
Block2:
	'BLOCK2' ...
As you can see, I use my EOL rule whenever I need to have at least one newline character end the line before anything else can happen. In this sense, this language is truly a whitespace-sensitive language since there must be at least one new-line detected after every parameter. A valid model for this might be:
BLOCK1
BEGIN
  PARAM1, abc, 123, def
  PARAM3, ghi
  PARAM2, jkl
END
whereas an invalid model might be:
BLOCK1
BEGIN
  PARAM1, abc, 123, def PARAM3, ghi
  PARAM2, jkl
END
The good news is that the editor seems to be working nicely. The bad news is that when I run the formatter, it adds a bunch of new lines everywhere with each invocation, and the text grows in length. So, formatting the valid model code above one time yields:
BLOCK1
BEGIN
  PARAM3, ghi
  PARAM2, jkl
END
Formatting again yields:
BLOCK1
BEGIN
  PARAM3, ghi
  PARAM2, jkl
END
My guess is that since I have made newline tokens separate from whitespace tokens the formatter API is getting confused. I have taken a look at IHiddenTokenHelper and DefaultHiddenTokenHelper in the hopes that I could override its behavior but have not yet had any success. I've set breakpoints in the setLinewrap() routine, but can't figure out exactly what is happening. Is there something else that I have to do to tell xtext that I want to consider all WS and EOL tokens when formatting?
Thanks in advance!
Re: Whitespace without newlines [message #1059189 is a reply to message #1059120] Fri, 17 May 2013 04:00 Go to previous messageGo to next message
this question may be beside the point, but couldn't you enforce correct linebreaks by validation and formatter. This should not be too difficult and provides the user with better error messages.
It is not always the best idea to put every language restriction into the grammar.
Alex
Re: Whitespace without newlines [message #1060269 is a reply to message #1059189] Thu, 23 May 2013 14:38 Go to previous messageGo to next message
Thanks Alexander for your reply.
Turns out I will have to make some compromises with the language in order to make the grammar less restrictive (i.e. get rid of that EOL in all of my rules) and use NodeModelUtils?? inside the validator to check for line breaks at a higher level. The reason is that the previous implementors of the language did not use an actual lexer, and defined character sets on an item-by-item basis. The line breaks are essentially all I have to distinguish some potential clashes in valid input that would otherwise cause the ANTLR lexer to bail. This problem is exacerbated by the possible inclusion of some keywords as identifiers. To implement the full language, the ANTLR grammar will only compile properly if I explicitly sprinkle newline tokens throughout my xtext grammar. It sure makes for a real mess, I know.
But what you've written has helped me rethink my approach to involving a less restrictive grammar at the expense of defining only a subset of the language in the hopes that it will still work for the majority of our use cases.
Thanks again,
Brad
Re: Whitespace without newlines [message #1060291 is a reply to message #1060269] Thu, 23 May 2013 19:12 Go to previous messageGo to next message
> use cases.
> Thanks again,
> Brad
You can write an external lexer that does the lookahead to find the
newlines and then emit the correct token.
That is what I need to do in cloudsmith / geppetto @ github to work
around ambiguities. The grammar (in Xtext) then only sees tokens that
are completely unambiguous, and it also sees NL as normal whitespace
that can be ignored.
- henrik
Re: Whitespace without newlines [message #1792872 is a reply to message #1060291] Wed, 25 July 2018 06:04 Go to previous messageGo to next message
Hi Brad,
I also met this problems in my project today.
So which way you used to solve this issue?
Could you please share to me?
Thanks.
Best Regards,
Devin
Re: Whitespace without newlines [message #1792874 is a reply to message #1792872] Wed, 25 July 2018 06:10 Go to previous message
Are you sure your usecase is not one for the whitespace aware languages like python that xtext meanwhile has (have a look st the docs)
Previous Topic:Multiple LanguageServers vs one JVM process
Next Topic:Using Xtext reserved wording withing DSL
Current Time: Sat Jul 26 21:57:54 EDT 2025
Powered by FUDForum. Page generated in 0.31134 seconds
