| Different ECF OSGi remote services (Neon.3 vs Photon) do not work together [message #1792752] | Mon, 23 July 2018 10:11  |  |
| Eclipse User  |  |  |  |  | Hi,
 I have a host application with OSGi remote service running on Oxygen and a client running on Neon. The client and the host could communicate well. No problem.
 When I upgraded the application host OSGi remote service to Photon, the client could not connect to the host anymore. And there is an NPE in the remote service admin:
 RemoteReferenceNotFoundException[targetID=StringID[ecftcp://192.168.5.175:63603/server], idFilter=[StringID[ecftcp://192.168.5.175:63603/server]], interfaces=[com.all4tec.sa.osgi.service.interfaces.api.IGlobalAnalysis], rsFilter=(&(ecf.rsvc.id=2))]
 at org.eclipse.ecf.osgi.services.remoteserviceadmin.RemoteServiceAdmin.importService(RemoteServiceAdmin.java:2418)
 at org.eclipse.ecf.osgi.services.remoteserviceadmin.RemoteServiceAdmin.importService(RemoteServiceAdmin.java:467)
 at org.eclipse.ecf.osgi.services.remoteserviceadmin.AbstractTopologyManager.handleECFEndpointAdded(AbstractTopologyManager.java:301)
 at org.eclipse.ecf.internal.osgi.services.distribution.BasicTopologyManagerImpl.handleEndpointAdded(BasicTopologyManagerImpl.java:107)
 at org.eclipse.ecf.internal.osgi.services.distribution.BasicTopologyManagerImpl.endpointChanged(BasicTopologyManagerImpl.java:176)
 at org.eclipse.ecf.internal.osgi.services.distribution.Activator$ProxyEndpointEventListener.deliverSafe(Activator.java:206)
 at org.eclipse.ecf.internal.osgi.services.distribution.Activator$ProxyEndpointEventListener.endpointChanged(Activator.java:183)
 at org.eclipse.ecf.osgi.services.remoteserviceadmin.EndpointDescriptionLocator$1.dispatchEvent(EndpointDescriptionLocator.java:219)
 at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
 at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
 The host ecf osgi remote admin version is 4.6.800
 and the client one is 4.4.2
 Does anyone experience the same problem, or having an idea to solve this?
 Thanks in advance.
FUDForum. Page generated in 0.04528 seconds
