Home » Modeling » TMF (Xtext) » Error on first generation regarding superType
Error on first generation regarding superType [message #1792763] Mon, 23 July 2018 11:43 Go to next message
With the DSL I create a number of subclasses instead of a single class for each needed class. In the example I only created one subclass but in the real usecase for DSL there could be too many to create an own class for each one. (thats the reason why I attempt to create subclasses)
The error only appears on the first code generation. Instead of the expected
"class A extends B"
Xtext generates
"class A implements B"
After the second code generation it works as expected.
The issue appears with the "IdWithKeyElementInferrerExtension" (part of the inferrer).
With the following method I could fix the problem with the generated class(container for the subclasses) itself:
void IJvmDeclaredTypeAcceptor.accept(JvmGenericType type, Procedure1<? super JvmGenericType> lateInitialization)
acceptor.accept(
		element.toClass(element.name) [
			packageName = element.packageName
		[superTypes += BaseClass.typeRef
But I have no clue how or if it is possible to set the inheritance reference for the subclasses in the "lateInitialization".
Example project is in the attachments.
Re: Error on first generation regarding superType [message #1792767 is a reply to message #1792763] Mon, 23 July 2018 12:13 Go to previous messageGo to next message
hi
please please provide minimal samples if you ask for help.
your inferrer pattern looks wired.
the default pattern is
acceptor.accecpt(element.toClass()) [
// late init
you can reference the outer class like this
 val outer = it
				if (!element.valueClasses.isEmpty) {
					for (vClass : element.valueClasses) {
						val className = vClass.name.toCamelCase
						members += element.toClass(className) [
							static = true
							//TODO
							superTypes += outer.typeRef
or you dont use that wired wired pattern for names
acceptor.accept(
element.toClass(element.packageName + "." +element.name)) [
superTypes += (element.packageName + "." +element.name) .typeRef
Re: Error on first generation regarding superType [message #1792800 is a reply to message #1792767] Tue, 24 July 2018 05:23 Go to previous messageGo to next message
I included the projects rather than parts of the code since I had no clue which part could case this behaviour.
After I changed the inferrer back to the default pattern and used the "outer" reference the "extends" is created correctly.
I use the weird name pattern "(element.packageName + "." +element.name) .typeRef" only within the acceptor for the visitor class for the parameter within the "toMethod".
If I simply use the name of the "valueClass" alone the reference doesn't get resolved.
		acceptor.accept(element.toClass(visitor)) [
			interface = true
				val vName = vClass.name.toCamelCase
				members += element.toMethod("visit" + vName, typeRef("void")) [
					abstract = true
					parameters += toParameter(
						vClass,
						"value",
						vName.typeRef
This leads to the generated code:
public abstract void visitSubClassOne(final SubClassOne value);
With the error that SubClassOne couldn't be resolved. (most likely because it is a subclass of the "parent" class)
If I use the weird name pattern:
			interface = true
					abstract = true
						vClass,
						"value",
						(element.fullyQualifiedName.toString + "." + vName).typeRef
This method gets generated:
public abstract void visitSubClassOne(final ParentClass.SubClassOne value);
Not ideal but since it is in the same package at least it worked.
The implicit question is: What would be the correct way to reference a subclass?
[Updated on: Tue, 24 July 2018 05:25] by Moderator
Re: Error on first generation regarding superType [message #1792824 is a reply to message #1792800] Tue, 24 July 2018 09:41 Go to previous messageGo to next message
so i said: use "(element.packageName + "." +element.name) .typeRef" everywhere
for the inner class please try path.to.Outer$Inner
Re: Error on first generation regarding superType [message #1792830 is a reply to message #1792767] Tue, 24 July 2018 10:13 Go to previous messageGo to next message
Christian Dietrich wrote on Mon, 23 July 2018 16:13
acceptor.accept(
Ok, sry! Missunderstood your response. Thought I should NOT use it.
The obvious answer for the subclass is almost embarrassing :D
(element.packageName + "." +element.name + "." + {classNameHere}).typeRef
Sometimes you are so fixed in your perspective that you don't see the simple solution. :(
Thank you very much!
Re: Error on first generation regarding superType [message #1793970 is a reply to message #1792824] Tue, 21 August 2018 07:53 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 24 July 2018 13:41
I got a follow up question regarding the syntax of the inner classes reference.
At the moment I'm trying to extend from inner classes.
The goal is to create stubs once for further non-generated custom code. (Generation Gap)
As a little overview:
interface I
abstract class A implements I {
	abstract class B extends A
	abstract class C extends A
class BImpl extends B {
Within the inferrer I use this part to generate the "Impl" classes and set the supertype:
for(vClass: element.valueClasses) {
	acceptor.accept(element.toClass(vClass.name +"Impl")) [
		superTypes += (element.packageName + "." + element.name + "." + vClass.name).typeRef
		members += element.toField("test", String.typeRef)
This is the reduced example I used to try to fix the extends "issues". (If you are wondering why there is no OutputConfigurationAdapter for the "generate once" part)
If I edit the generated file and change the implements back to extends all seems fine and it can be resolved. Therefore I guess XText cannot find or know the inner class during the generation?
The pattern "(element.packageName + "." + element.name + "." + vClass.name).typeRef" works in the method context:
	members += element.toMethod("visit" + vName, void.typeRef) [
		abstract = true
		parameters += vClass.toParameter("value", (element.packageName + "." + element.name+ "." + vName).typeRef)
I hope I provided enough context without an updated example project.
Re: Error on first generation regarding superType [message #1793971 is a reply to message #1793970] Tue, 21 August 2018 07:59 Go to previous messageGo to next message
no please provide a hello world grammar and inferrer showing the problem
Re: Error on first generation regarding superType [message #1793973 is a reply to message #1793971] Tue, 21 August 2018 08:07 Go to previous messageGo to next message
Model:
	"model" name=ID;
	def dispatch void infer(Model element, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
		acceptor.accept(element.toClass("dummy.Outer")) [
			members+=element.toClass("Inner1") [
				static = true
			members+=element.toClass("Inner2") [
				static = true
		acceptor.accept(element.toClass("dummy.Outer2")) [
			superTypes+="dummy.Outer$Inner1".typeRef
works fine for me
Re: Error on first generation regarding superType [message #1793974 is a reply to message #1793971] Tue, 21 August 2018 08:26 Go to previous messageGo to next message
Well. Nevermind. The one thing I didn't try was taking your "suggestion"/answer literally!
"path.to.Outer$Inner " was the solution.
Instead of "(element.packageName + "." + element.name + "." + vClass.name).typeRef" I tried this during building the example
"(element.packageName + "." + element.name + "$" + vClass.name).typeRef" and it works.
Edit: And again, you are faster as usual ;)
[Updated on: Tue, 21 August 2018 08:48] by Moderator
Re: Error on first generation regarding superType [message #1794286 is a reply to message #1793974] Tue, 28 August 2018 09:03 Go to previous messageGo to next message
This is a simplified version of my Xtext project with the same extends/implements "error".
I have no clue how to fix it. Like I stated above, I had a working solution but for some reason that I can't figure out the generation now fails.
For the context how I "test" the generation:
* Delete the generated package by hand
* Add a single character/comment or whitespace to the dsl and save it.
Re: Error on first generation regarding superType [message #1794299 is a reply to message #1794286] Tue, 28 August 2018 11:22 Go to previous messageGo to next message
again. already have you the answer before
bad:
acceptor.accept(element.toClass(element.name + implExtention)) [
packageName=package
good:
acceptor.accept(element.toClass(package + "." + element.name + implExtention)) [
Re: Error on first generation regarding superType [message #1794398 is a reply to message #1794299] Thu, 30 August 2018 05:46 Go to previous message
Thank you very much! In the small example this looks stupid.. but it was the last toClass where I didn't change it and just c&p it to the example.
Previous Topic:Add Xtext nature during import of projects containing DSLs
Next Topic:Library issue with New Project Wizard in 2.14
Current Time: Sun Jul 20 22:23:40 EDT 2025
Powered by FUDForum. Page generated in 0.07180 seconds
