Home » Modeling » Papyrus » Please vote for Bug 536964 - Several issues for sequence diagram in Papyrus 4.0
Please vote for Bug 536964 - Several issues for sequence diagram in Papyrus 4.0 [message #1792197] Thu, 12 July 2018 09:42 Go to next message
Bug report submitted and please vote for bug or let me know if any workarounds! Here is the bug report:
1. The interaction frame (auto created when sequence diagram is created) cannot be resized (I have heard others say that is can be resized vertically, but in my system it does not work)
2. In my system no sequence diagrams can be saved as images, exported to HTML or copied/pasted to MS word or powerpoint. Export to image file results in following error message "Copy diagram to image file could not be completed Reason negative width".
3. No diagrams can be printed
4. I cannot connect comments to any diagram object in sequence diagrams. Comment links are not in the sequence diagram palette (so maybe not implemented??)
5. When deleting a class operation that was created in Oxygen, Photon hangs for several minutes or crashes (a workaround that sometimes works is to first move the operation to a new class, then delete that class)
[Updated on: Thu, 12 July 2018 09:42] by Moderator
Re: Please vote for Bug 536964 - Several issues for sequence diagram in Papyrus 4.0 [message #1792202 is a reply to message #1792197] Thu, 12 July 2018 10:19 Go to previous messageGo to next message
Hi Richard,
1) Indeed, it's not possible to manually resize the interaction. Automatic resize is the only way (So the interaction can grow, but it can't shrink below its default size)
2) 536030: [All Diagrams] Incorrect default value for LineWidth https://bugs.eclipse.org/bugs/show_bug.cgi?id=536030
=> This is fixed (Unfortunately, it got merged just a few days after code freeze, so the fix is not present in the release :( )
3) Print is a default GMF feature, I don't know if we ever properly supported it in Papyrus (Even though it appears in several places).
4) Works for me (Comment Link is present at the end of the palette, just before Constraint Link and Context Link)
[Updated on: Thu, 12 July 2018 10:19] by Moderator
Re: Please vote for Bug 536964 - Several issues for sequence diagram in Papyrus 4.0 [message #1792205 is a reply to message #1792202] Thu, 12 July 2018 11:07 Go to previous messageGo to next message
Camille, many thanks for your helpful feedback as usual!
1. Hopefully manual interaction sizing will be fixed soon
2. Waiting impatiently for update!
3. Yea print is no biggie... diagram export is a bit more troublesome (I use Papyrus to teach UML....)
4. Reinstalled and found the Comment link - thanks for tip!
5. This one is weird. Maybe a corrupted archive file in my Oxygen model? Has anyone seen something like this? I have Windows 10 with 32 bit Java. During Papyrus crashes I noticed my company antivirus (McAfee) was eating up 16-20% of CPU resources... Hmmmmmm
Re: Please vote for Bug 536964 - Several issues for sequence diagram in Papyrus 4.0 [message #1792213 is a reply to message #1792205] Thu, 12 July 2018 12:01 Go to previous messageGo to next message
Hi Richard,
1. I personally regard the automatic resize feature far superior. But I belong to a minority in europe as I own a car with an automated gearbox ;-)
2. is clearly a non-issue to me
3. is clearly a non-issue to me
4.works for me
5. I think McAfee's behavior is clearly an out of scope issue in this context
/pica
[Updated on: Thu, 12 July 2018 12:02] by Moderator
Re: Please vote for Bug 536964 - Several issues for sequence diagram in Papyrus 4.0 [message #1792676 is a reply to message #1792205] Fri, 20 July 2018 23:13 Go to previous message
An update for anyone interested: the only way I could resolve 5. Papyrus crashes was to delete the elements I created with Oxygen from my model (it included several sequence diagrams). Seems like a backwards compatibility issue.
Previous Topic:Papyrus 3.0.0 - Where is SysML profile?
Next Topic:Hyperlink on HTML report
Current Time: Sun Jul 27 03:52:06 EDT 2025
Powered by FUDForum. Page generated in 0.07621 seconds
