Re: Custom node with Sirius [message #1792720 is a reply to message #1792653] |
Mon, 23 July 2018 04:15  |
The essential to understand is when you start using extension point to define your odesign, you must have your design project in the first launched environment. And your sample in the runtime you launch from the first one.
Then if you do a modification in your design, you have to quit your runtime and relaunch it so it can be taken in consideration.
If you are doing only design and services modification, in the first environment, with Sirius 6.0.0 you can use a reload button available in menu bar that will have the same effect as a relaunch of the runtime environment. I.e your modification will be taken in consideration for your sample diagrams and others.
Don't hesitate to continue to ask questions,
FUDForum. Page generated in 0.06268 seconds
