Home » Modeling » UML2 » XML/XMI import/export issues?
XML/XMI import/export issues? [message #477505] |
Wed, 11 June 2008 08:29  |
Originally posted by: kmcgarghan.csc.com
We bought Visual Paradigm to draw UML diagrams [including collaborative
models], and were assured we'd be able, if need be, to convert the XMI to
XML and import into either Eclipse, MyEclipse, or Visio, which are the
preferred tools used by our client. [We need to supply the client with
editable overview, golden path, and alternate path collaboration diagrams.]
We cannot get Visio to import the drawings. We wrote Visual Paradigm about
the problem, and they initially encouraged us to try both in Eclipse and
in MyEclipse.
Having done so, we find that we cannot get either Eclipse or MyEclipse to
import the diagrams as diagrams either, although both programs do 'see'
the attributes and elements as XML.
We wrote Visual Paradigm about the problem again, and this is what they
said:
"Subject [#ZZQ-732542]: problems with XMI
Our engineers had investigated on your problem but unfortunately didn't
able to find you the solution. We have tried the MyEclipse and seems
MyEclipse is still using UML 1.x (but our diagrams are UML 2.1). I think
that's the reason why they cannot import our XMI.
We also tried an alternative solution, which is eclipse uml2tool plugin.
Eclipse uml2tool was able to import our model (XMI 2.1 for UML2), and
re-construct the diagram based on the model (the diagram layout will be
different). But it's shame that they do not support sequence diagram and
communication/collaboration diagram.
Therefore currently there is no way to import our model (communication
diagram) into eclipse in editable way. We are very sorry about this. If
you need any help, please do not hesitate to contact me."
Does anyone know of a way we can get those diagrams exported successfully
AS editable diagrams to Eclipse, MyEclipse, Visio, or some other
widely-used tool?
--kmcgarghan @ csc.com, kmcgarghan @ yahoo.com
Re: XML/XMI import/export issues? [message #477506 is a reply to message #477505] |
Wed, 11 June 2008 10:04   |
Hi Kim,
I've cc'd the uml2tools newsgroup about this. The UML2Tools group would be
able to let you know the status of the various supported diagrams.
It would be nice to keep the newsgroup product neutral but another tool that
supports all the diagram types except timing diagrams is IBM's RSx. It is
built on the opensource UML2 project. It's not freeware however.
Somewhere in the history of postings there was a link to applications that
use the opensource UML2 project. You will probably find a freebie there
that supports Sequence diagrams.
- James.
"Kim McGarghan" <kmcgarghan@csc.com> wrote in message
news:723041abad26765c9b84ee524b352bda$1@www.eclipse.org...
> diagrams.]
> in MyEclipse.
> widely-used tool?
Re: XML/XMI import/export issues? [message #477507 is a reply to message #477506] |
Wed, 11 June 2008 11:42   |
http://wiki.eclipse.org/MDT-UML2-Tool-Compatibility
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:g2om0k$llo$1@build.eclipse.org...
> Hi Kim,
> be able to let you know the status of the various supported diagrams.
> that supports all the diagram types except timing diagrams is IBM's RSx.
> It is built on the opensource UML2 project. It's not freeware however.
> Cheers,
> - James.
>> diagrams.]
>> about the problem, and they initially encouraged us to try both in
>> Eclipse and in MyEclipse.
>> widely-used tool?
Re: XML/XMI import/export issues? [message #477511 is a reply to message #477505] |
Thu, 12 June 2008 09:35   |
Kim,
Note that interchange of diagrams is still not viable in today's tools (in
the absence of a robust diagram interchange specification). Interchange of
the semantic elements is, as indicated by the vendor below, possible, so I'm
afraid the best you can hope for at this point is to export/import the
semantic elements and recreate the diagrams using the other tool...
Kenn
> diagrams.]
> in MyEclipse.
> widely-used tool?
Re: XML/XMI import/export issues? [message #477561 is a reply to message #477505] |
Tue, 01 July 2008 10:58   |
> to XML and import into either Eclipse, MyEclipse, or Visio, which are
> the preferred tools used by our client.
This was disingenuous, to put it politely, of the vendor. In the decade
that the OMG has been working on this graphical modeling language (UML),
there's never been a single instance of graphical interchange between
heterogenous tools.
MyEclipse's UML support is based on a closed source fork of ArgoUML
0.16, which was a UML 1.3-based tool. The latest version of UML that
Visio even attempted to implement was something like UML 1.1.
tools (in
Interchange of
so I'm
Semantic data interchange is not completely impossible, but it's often
difficult. In this particular case with three different versions of UML
involved, it will be especially difficult because none of the versions
of UML are compatible with each other (UML 1.5 is a superset of UML 1.4,
but it's not represented among the tools here).
The OMG is a vendor run trade group and standards body, so they're going
to do what the vendors tell them to. Customers need to impress upon
their vendors that the current situation is unacceptable and that
they're not willing to have their design data held hostage any longer.
Since the thread contains a plug for IBM, I'll note that IBM holds the
chair of the group that does this standards work at the OMG as well as a
dominant positition in this market segment, so they probably deserve a
disproportionate share of the blame for the current state of affairs.
Tom
Re: XML/XMI import/export issues? [message #477562 is a reply to message #477561] |
Tue, 01 July 2008 12:35   |
--------------030203010004070709030802
Tom,
I was at the OMG meetings last week and my impression is that there's
more than enough blame to be shared by everyone involved.
< http://ed-merks.blogspot.com/2008/06/eclipse-omg-symposium.h tml>
From what I've heard, the specification for how to represent diagram
information is so unworkable as to be effectively unimplementable. It
should be possible to exchange conforming serializations of the
underlying UML instances, but diagram exchange I think is still a great
many years away.
>> collaborative models], and were assured we'd be able, if need be, to
>> convert the XMI to XML and import into either Eclipse, MyEclipse, or
>> Visio, which are the preferred tools used by our client.
> decade that the OMG has been working on this graphical modeling
> language (UML), there's never been a single instance of graphical
> interchange between heterogenous tools.
> tools (in
> Interchange of
> possible, so I'm
> UML involved, it will be especially difficult because none of the
> versions of UML are compatible with each other (UML 1.5 is a superset
> of UML 1.4, but it's not represented among the tools here).
> going to do what the vendors tell them to. Customers need to impress
> upon their vendors that the current situation is unacceptable and that
> a dominant positition in this market segment, so they probably deserve
> a disproportionate share of the blame for the current state of affairs.
> Tom
<html>
<head>
http-equiv="Content-Type">
</head>
Tom,<br>
<br>
more than enough blame to be shared by everyone involved. <a
href=" http://ed-merks.blogspot.com/2008/06/eclipse-omg-symposium.h tml"><br>
</a>
<blockquote><a
href=" http://ed-merks.blogspot.com/2008/06/eclipse-omg-symposium.h tml"> http://ed-merks.blogspot.com/2008/06/eclipse-omg-symposium.h tml</a><br>
</blockquote>
Re: XML/XMI import/export issues? [message #477846 is a reply to message #477774] |
Fri, 17 October 2008 18:45   |
Kenn Hussey wrote:
> OK, thanks Vlad. Just let us know when it's available.
> Kenn
> "Vlad Varnica" <varnica@omondo.com> wrote in message
> news:a4ea15e3f0f3fa9832b5058e9e21a4b9$1@www.eclipse.org...
>> My first tutorial test failed, because we have an EMF problem with
>> template signature duplication. This problem has already been reported
>> previously by other community members !! Except this duplication problem
>> everything is just fine :-). UML ID remained the same (e.g. the source
>> model ID versus the targeted merged model). Dynamic navigation was
>> possible in order to recreate diagram views from the RSA/ EclipseModeling/
>> EclipseUML merged models.
>> Linking models elements being in different models were possible. Adding
>> dependencies, inheritance, associations etc...
>> My test was:
>> First I have created three different projects with RSA 7, Eclipse Modeling
>> Tools few small models (e.g. default package level is used) and
>> EclipseUML.
>> Then I have created a new EclipseUML Project and created a class diagram.
>> Finally I have merged all models coming from different tools by adding one
>> element of each model (e.g. the model merge is immediately activated after
>> the first drag and drop).
>> The tutorial will therefore be delayed because our research lab office
>> will be closed next week and we need to fix the reported EMF problem.
>> Thanks,
>> Vlad VARNICA
>> OMONDO
Hi Kenn,
The build is finish and will be public next week.
All bugs have been fixed and everything is just perfect.
You can for example have a RSA, or Eclipse Modeling Project model and just
merge them inside EclipseUML.
The question is now why this approach is important and how to explain it.
I think what is important is to be able to model multiple projects.
For example JEE or Java projects are already composed by multiple
projects.
Why UML should only be working at diagram level and not even at project
level ? Why this limitation ?
Another issue is the interoperability between different tools. I mean that
inside the same company you can have architects using RSA, Togethersoft,
etc... and java developers using EclipseUML, Visual ... . Being able for
example by just drag and drop to merge different tools models inside
EclipseUML allows architects to immediately forward theirs project to the
implementation stage. The UML modeling project is now agile from
requirements to implementation without loosing any information.
Another important concept is the dynamic modeling. I mean that being able
to merge different tools model inside EclipseUML model and get a
consolidated model open new perspective. Let's talk about a kind of
company UML super datawharehouse. This will allow dynamic navigation
inside company models. If you look at BI and how they use the datas to
extract critical information then you can see the new frontier of merging
multiple projects and using dynamic navigation inside your models.
I think that these concepts are important and give incredible
opportunities to move from a static UML based on model and model
transformation to dynamic UML based on model datawarehouses.
These concepts are possible because Omondo 2008 architecture is based on a
native GEF, EMF and xmi model integration.
I will come back shortly to explain our vision.
Thanks Kenn for your answer :-)
Vlad VARNICA
Omondo
Re: XML/XMI import/export issues? [message #626696 is a reply to message #477505] |
Hi Kim,
- James.
> diagrams.]
> in MyEclipse.
> widely-used tool?
Re: XML/XMI import/export issues? [message #626697 is a reply to message #477506] |
> Hi Kim,
> Cheers,
> - James.
>> diagrams.]
>> widely-used tool?
Re: XML/XMI import/export issues? [message #626701 is a reply to message #477505] |
Kim,
Kenn
> diagrams.]
> in MyEclipse.
> widely-used tool?
Re: XML/XMI import/export issues? [message #626752 is a reply to message #477505] |
heterogenous tools.
tools (in
Interchange of
so I'm
Tom
Re: XML/XMI import/export issues? [message #626753 is a reply to message #477561] |
Tom,
many years away.
> tools (in
> Interchange of
> possible, so I'm
> Tom
<html>
<head>
</head>
Tom,<br>
<br>
</a>
<blockquote><a
</blockquote>
Re: XML/XMI import/export issues? [message #627049 is a reply to message #477774] |
> Kenn
>> My test was:
>> EclipseUML.
>> Thanks,
>> Vlad VARNICA
>> OMONDO
Hi Kenn,
projects.
Vlad VARNICA
Omondo
Current Time: Sat Jul 26 21:38:54 EDT 2025
Powered by FUDForum. Page generated in 0.08258 seconds
