Home » Eclipse Projects » GEF » Source and doc. plugins don't work in GEF 3.1M6?
Source and doc. plugins don't work in GEF 3.1M6? [message #178910] Sun, 24 April 2005 08:23 Go to next message
Originally posted by: martinek.fit.vutbr.cz
I have just installed Eclipse 3.1M6 and GEF 3.1M6 and it seems that
these plugins don't work:
org.eclipse.draw2d.doc.isv_3.1.0
org.eclipse.gef.doc.isv_3.1.0
org.eclipse.gef.source_3.1.0
I can neither read the documentation of GEF nor survey the source code.
Those plugins are not visible in Window-Preferences-Target
Platform-Plugins. I can see there only org.eclipse.draw2d and
org.eclipse.gef. I tried to adjust the plugin.xml files of those plugins
according to some working plugins but with no effect.
The plugins org.eclipse.gef_3.1.0 and org.eclipse.draw2d_3.1.0 are
working normally. I have Mandrakelinux 10.1 and jdk1.5.0_02. Does anyone
know what is wrong?
David
Re: Source and doc. plugins don't work in GEF 3.1M6? [message #179227 is a reply to message #178910] Mon, 25 April 2005 22:36 Go to previous messageGo to next message
It works for me.
"David Martinek" <martinek@fit.vutbr.cz> wrote in message
news:d4g38o$mo6$1@news.eclipse.org...
> Hello,
> know what is wrong?
> David
Re: Source and doc. plugins don't work in GEF 3.1M6? [message #179265 is a reply to message #179227] Tue, 26 April 2005 07:41 Go to previous messageGo to next message
I've just solved the problem. I had older versions of Eclipse (3.0.0,
3.1M5a) in separate directories (with several versions of GEF) but there
was only one .eclipse directory with configuration in my home directory.
After deletion the .eclipse directory and restarting Eclipse, all is
working fine.
I suppose the problem was caused by merging of old and new configuration
files of Eclipse 3.1Mxx and GEF 3.xx. For example, I found manifest
files org.eclipse.gef.source_3.0.1.MF and
org.eclipse.gef.source_3.1.0.MF together in the configuration directory
~/.eclipse/org.eclipse.platform_3.1.0/configuration/org.ecli pse.osgi/manifests
but I have just had installed only the 3.1 version of GEF.
Pratik Shah wrote:
> It works for me.
>>Hello,
>> know what is wrong?
>>Thanks,
>>David
Re: Source and doc. plugins don't work in GEF 3.1M6? [message #179308 is a reply to message #179265] Tue, 26 April 2005 10:28 Go to previous message
Which platform are you using?
news:d4l9je$bnk$1@news.eclipse.org...
> working fine.
> files of Eclipse 3.1Mxx and GEF 3.xx. For example, I found manifest files
> org.eclipse.gef.source_3.0.1.MF and org.eclipse.gef.source_3.1.0.MF
Previous Topic:Intersects
Next Topic:Nested Layout with CompoundDirectedGraphLayout
Current Time: Thu Jul 24 23:05:48 EDT 2025
Powered by FUDForum. Page generated in 0.07381 seconds
