Home » Eclipse Projects » Eclipse Titan » Test Performance in TITAN using Timestamps
Test Performance in TITAN using Timestamps [message #1791877] |
Fri, 06 July 2018 08:15  |
I would like to conduct a test performance between a server and a client by calculating the round trip time of one request. For this propose I have been using timer and to print out the value of the timer when receiving the server response. Although this approach works, when I conducted a traffic analyzer using wareshark, the results are quite different!
Therefore I would like to know how can i use timestamps in titan ?
thanks and regards
Re: Test Performance in TITAN using Timestamps [message #1792247 is a reply to message #1791877] |
Fri, 13 July 2018 04:17   |
Hi raed,
it's nothing surprising that the two timestamps , the one in Wireshark and the one in Titan , are different , although they should not differ by more than
maybe a few miliseconds.
If your processes are running on one processor thread, then Wireshark and Titan will execute sequentially, with a timing determined by the operating system, which presumably is a non-real time OS.
If they are executing on parallel processor threads , again, there's no reason the timestamps should be exactly the same.
If you are after ultimate accuracy you will have to use a real time operating system, possibly executing on a hardware that supports it;
we had experience with Titan running in such environment, but for a specific RTOS probably specific problems will have to be addressed.
Please remember that the (non-real time) operating system will distribute the execution between different processes as it sees fit ;
also , the more Titan logging you have activated ( as writing to hard disk is slow ) the more incertitude is introduced in the accuracy of timestamps .
In a generic environment you can trust the accuracy of Titan timestamps down to maybe around one millisecond, but in a specific environment you will have to run measurements to know exactly.
However performance and accuracy are two different things, and it's not clear from the above which is really important for you.
Titan is perfectly capable of running scalable traffic that can be used for performance test; we have also published code that supports this, see
RIoT - the IoT load/performance generator based on TTCN-3 and Titan
https://www.eclipse.org/forums/index.php/t/1093619/
Best regards
Elemer
Re: Test Performance in TITAN using Timestamps [message #1792249 is a reply to message #1792247] |
Fri, 13 July 2018 05:07   |
Hi raed ,
one more thing: when sending small TCP packets (less than 1000 bytes) the default behaviour of the kernel is to delay sending by 100 mseconds , with the reason that maybe there's some
data coming that can be sent together. This delay can affect timestamps significantly..
For instance, in the IPL4 test port this behaviour can be controlled by the boolean option no_delay:
type union Option {
ReuseAddress reuseAddress,
TcpKeepAlive tcpKeepAlive,
SctpEventHandle sctpEventHandle,
TcpKeepAlive sslKeepAlive,
HostList sctpAdditionalLocalAddresses ,
integer sctpEINConfigGroup,
Linger_opt solinger,
SSL_proto_support ssl_support,
boolean no_delay,
charstring dtlsSrtpProfiles,
SSL_cert_options cert_options,
boolean freebind,
record of charstring alpn_list,
charstring tls_hostname,
UDP_ENCAP_Param udp_encap,
integer dscp,
MTU_discover mtu_discover,
PSK_options psk_options
BR
Elemer
Re: Test Performance in TITAN using Timestamps [message #1792601 is a reply to message #1792572] |
Fri, 20 July 2018 02:42  |
Hi Raed,
again, accuracy for a generic Linux environment should be around one msec;
a RTOS offers a non-buffering deterministic execution so certainly accuracy will improve; there are many RTOS's out there, I recommend you chose one
close to Linux, as it will have to support the gnu toolchain (gcc, make , ld).
One more thing you should keep in mind: timestamping can be done in different protocol layers, see below:
technically, for UDP timestamping can be done in the kernel , or the test port code , which connects the kernel stack to the abstract application layer written in TTCN-3 or in the application layer itself.
For TCP timestamping can only be done in the test port code (after message extraction), as the kernel is agnostic to the concept of TCP message , or the application layer.
Timestamping in the kernel might improve accuracy, but it's available for UDP only and it assumes the TTCN-3 real time extension, which is not yet supported by Titan.
However for TCP timestamping in the kernel is not an option. (this is the reason we did not add the real-time extension as it would not significantly improve the accuracy of timing in Titan)
As for RIoT, if you successfully build Titan on Beaglebone, then RIoT should work as well. We have built Titan on Raspberry, Hummingboard etc. so Beaglebone should not be a problem.
The RIoT GUI is optional, it also has a command line interface, so you don't need desktop to run it.
Best regards
Elemer
[Updated on: Fri, 20 July 2018 02:46] by Moderator
Current Time: Wed Jul 23 22:52:34 EDT 2025
Powered by FUDForum. Page generated in 0.09094 seconds
