Home » Modeling » EMF » [CDO] Inefficient SQL generated for CDORepository inserts/removes
[CDO] Inefficient SQL generated for CDORepository inserts/removes [message #1792170] Thu, 12 July 2018 06:03 Go to next message
We are experiencing servere performance issues when inserting / removing Objects from a rather small (~1500 entries) CDORepository which is backed by an Oracle database.
It seems to keep ordering, CDO generate a huge amount of SQL statements that are executed non-batched (~3 for each CDO object contained in the Repository) - adding a single Object at the beginning of the Repository causes 4500 sql statements to be generated, multiplied with ~15ms round trip latency this results in over a minute the modification takes.
This is caused by the moveOneUp/moveOneDown methods called by AuditListTableMappingWIthRanges$ListDeltaVisitor.
This was observed when using cdo.server.db.4.4.0.v20160607-1254, but looking at the latest CDO code those methods seem to be more or less working the same way.
Is there any way to make inserts/removes to/from a CDORepository more efficient with a database store?
Thank you in advance & best regards, Clemens
[Updated on: Thu, 12 July 2018 06:05] by Moderator
Re: [CDO] Inefficient SQL generated for CDORepository inserts/removes [message #1792253 is a reply to message #1792170] Fri, 13 July 2018 05:32 Go to previous messageGo to next message
Linuxhippy Mising name wrote on Thu, 12 July 2018 12:03
Yes, EMF's many-valued features are generally implemented with Lists, which are ordered. If you define such a feature as "Ordered=false" in the Ecore model, CDO uses a slightly optimized org.eclipse.emf.internal.cdo.CDOObjectImpl.CDOStoreUnorderedEList, see org.eclipse.emf.internal.cdo.CDOObjectImpl.createList(EStructuralFeature).
It's possible that there's room for optimization, but I'd need to know exactly what operations/modifications you've done.
By "at the beginning of the Repository" you mean "into a new, empty repository"? Then, what are those 4500 statements? A single, new object should not cause any moveOneUp/Down() calls. Are they "CREATE TABLE" statements? How big is your meta model? What is this object? Does it have many-valued features with many elements? I need more details (ideally an executable test case to reproduce the scenario) to properly comment...
Indeed it seems that AuditListTableMappingWIthRanges$ListDeltaVisitor might profit from statement batching. Are you interested in contributing a respective patch? NonAuditListTableMapping$ListDeltaWriter already seems to employ batching.
Re: [CDO] Inefficient SQL generated for CDORepository inserts/removes [message #1792376 is a reply to message #1792253] Mon, 16 July 2018 11:28 Go to previous messageGo to next message
Hi Ralf,
I mean inserting an element at e.g. position 5 into a Repository already containing with 1500 elements (so moving is required).
At least for my use-case moveOneDown is called (to make space for the new element at the specified index, which was occupied before) - moveOneDown in my case:
1. Tries ot update, which returns 0 -> no element matched
2. loads the value from the DB (getValue)
3. removeEntry -> 2 SQL staments (remove + update)
4. addEntry (insert)
Without batching all those steps are performed synchronously with the DB server. So while it might be great scalability wise to be able to change ordering of a 1 nbillion-element-list without loading into memory, it would take almost forever.
I currently solved it by moving all the affected entries from oracle into an in-memory database (hsqldb), run the current code as is and later re-insert it into oracle.
This helped to speed up moveOneDown/Up from 80s to ~300ms.
Maybe I can contribute a proper implementation without using an in-memory intermediate database.
Re: [CDO] Inefficient SQL generated for CDORepository inserts/removes [message #1793011 is a reply to message #1792376] Fri, 27 July 2018 09:10 Go to previous message
I think an intermediate in-memory database is no option for CDO. I would first try to apply stement batching similar to NonAuditListTableMapping.ListDeltaWriter. I'm currently not sure how the calls AuditListTableMappingWithRanges.getValue() would interfere with a batching approach, but it would be great if you could try it out. Let me know if you need further help.
If batching alone isn't enough, we could discuss possible other/additional options.
BTW., who is Ralf?
Previous Topic:[CDO] Queries related to Standalone Client - Reg.
Next Topic:[CDO] Individual access rights for many resources
Current Time: Thu Jul 24 21:45:19 EDT 2025
Powered by FUDForum. Page generated in 0.06313 seconds
