Home » Eclipse Projects » Sirius » Activate Filter by Default
Activate Filter by Default [message #1791970] Mon, 09 July 2018 04:19 Go to next message
Hello Community,
I have defined some filters in odesign.
Does anyone know how to activate filters by default?
Bo
Re: Activate Filter by Default [message #1791976 is a reply to message #1791970] Mon, 09 July 2018 05:33 Go to previous messageGo to next message
I may be wrong but if you need to activate filters by default, I think that it means that the elements you need to be filtered should be placed in a different layer that is not active by default. Also this way to display them, instead of deactivating a filter, you would activate a layer.
If you still want to activate a filter by default, you will need to do it programatically using the runnable ChangeFilterActivation and you can access all your filters from a DDiagram by calling the methods getDescription().getFilters(). You can trigger this from a ResourceSyncClient when notified of EditingSessionEvent.REPRESENTATION_ABOUT_TO_BE_CREATED_BEFORE_OPENING, you should have a look to SaveSessionWhenNoDialectEditorsListener for example.
Steve
Re: Activate Filter by Default [message #1792091 is a reply to message #1791976] Wed, 11 July 2018 04:41 Go to previous messageGo to next message
I think Concerns is used for set the default filter, but it can't work now.
Re: Activate Filter by Default [message #1792096 is a reply to message #1792091] Wed, 11 July 2018 05:34 Go to previous messageGo to next message
Concerns are an old feature kept for historical reasons but is pretty much obsolete. I would not recommand to use them.
Steve
Re: Activate Filter by Default [message #1792370 is a reply to message #1791976] Mon, 16 July 2018 10:42 Go to previous message
Thanks for the reply!
I'll try the programmatical method.
Previous Topic:Update model properties from custom widget
Next Topic:Is there any way we can apply company logo as the watermark for canvas?
Current Time: Fri Jul 25 23:39:16 EDT 2025
Powered by FUDForum. Page generated in 0.04455 seconds
