ERROR: org.eclipse.equinox.p2.touchpoint.natives code=0 The action chmod failed [message #1524860] |
Tue, 23 December 2014 13:14  |
Hello, I'm trying to use Oomph to set up a dev environment for the Papyrus project, but I get the following error:
[12:39:25] ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while installing the items
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:217)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$1.commit(ProfileTransactionImpl.java:438)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:311)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:692)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2585)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2541)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2531)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2461)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:532)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:620)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__Users_jc236769_OomphRoot_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]org.eclipse.rcp.configuration_root.win32.win32.x86_64 1.0.100.v20141210-1822, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.ChmodAction).
ERROR: org.eclipse.equinox.p2.touchpoint.natives code=0 The action chmod failed - file C:\Users\jc236769\OomphRoot\eclipse\eclipse.exe does not exist
[12:39:25] Took 41 seconds.
[12:39:25] There are failed tasks.
[12:39:25] Press Back to choose different settings or Cancel to abort.
Well, Knowing that I'm on Windows it's akwkard to see it trying to perform a chmod . I'm using build 719.
Any ideas? Thanks !
Re: ERROR: org.eclipse.equinox.p2.touchpoint.natives code=0 The action chmod failed [message #1524899 is a reply to message #1524860] |
Tue, 23 December 2014 13:42   |
Hi Juan,
I've just set up a Papyrus environment myself on Windows and had absolutely no problems. Have you checked that the file
C:\Users\jc236769\OomphRoot\eclipse\eclipse.exe does exist?
I'm already packing for my christmas travel so it might take a couple days until I can try to analyze your problem.
Merry christmas to you and
Cheers
/Eike
http://www.esc-net.de
Am 23.12.2014 um 19:14 schrieb Juan Cadavid:
> Well, Knowing that I'm on Windows it's akwkard to see it trying to perform a chmod :). I'm using build 719.
> Any ideas? Thanks !
FUDForum. Page generated in 0.06830 seconds
