Home » Eclipse Projects » RCP Testing Tool » How to scroll a view ?(What are the ECL command that could allow me to scroll down a view ?)
How to scroll a view ? [message #1791174] Mon, 25 June 2018 09:10 Go to next message
In one of my tests, written in ECL with RCPTT, I need to check the value of a register. To do so I check the value shown in the registers view
The problem is that the register I'm looking for is far in the list. And the debugger load the value dynamically, when scrolling the list.
57-data-list-register-values --thread 1 --frame 0 x 15
57^done,register-values=[{number="15",value="0x0"}]
(gdb)
58-data-list-register-values --thread 1 --frame 0 N 15
58^done,register-values=[{number="15",value="0"}]
So in order to check the value of my register, I need to force a scrolling to force the debugger to load the value. So here's my question : how can I make the test scroll the view ?
If I don't do this, the execution fail when I try to select the register using this:
get-view Registers | get-tree | get-item "General Registers/MY_REGISTER"
It throws me:
Failed to set selection: [[General Registers, MY_REGISTER]].
I've tried to use the below code to force the discovery but it didn't worked.
with [ get-view Registers | get-tree ] {
	get-item "General Registers" | expand-all
	select "General Registers/MY_REGISTER" |
Re: How to scroll a view ? [message #1791353 is a reply to message #1791174] Thu, 28 June 2018 06:16 Go to previous messageGo to next message
Hi Vincent,
There is no command to scroll a view down, but you can try to achieve the same result by using 'try' command with 'times' parameter:
try -times 5 -command { get-view Registers | get-tree | select "General Registers/MY_REGISTER" } -catch { }
Re: How to scroll a view ? [message #1791541 is a reply to message #1791353] Mon, 02 July 2018 04:42 Go to previous message
Hi Viktoria,
Thanks for your answer.
I'm a bit frustrated that there's no such commmand :-(
Edit: I've tried your method, but it doesn't work ... , my bad, I've made mistakes in my test, now it works !!
The use of the command "select" force the system to go through the whole tree to find the item to select. So it force the discovery of all the registers.
I use a first "select" inside a try-catch block because it will failed (don't know why). Then a second one (that will work since registers has been discovered now) to perform what I want to perform.
try -command { select "General Registers/MY_REGISTER" } -catch { }
select "General Registers/MY_REGISTER" | get-menu "Number Format/Hex" | click
[Updated on: Mon, 02 July 2018 08:44] by Moderator
Previous Topic:Code coverage with RCPTT test scripts
Next Topic:TreeItem foregroundColor always Black
Current Time: Sun Jul 27 11:53:47 EDT 2025
Powered by FUDForum. Page generated in 0.04936 seconds
