How to scroll a view ? [message #1791174] |
Mon, 25 June 2018 09:10  |
In one of my tests, written in ECL with RCPTT, I need to check the value of a register. To do so I check the value shown in the registers view
The problem is that the register I'm looking for is far in the list. And the debugger load the value dynamically, when scrolling the list.
57-data-list-register-values --thread 1 --frame 0 x 15
57^done,register-values=[{number="15",value="0x0"}]
(gdb)
58-data-list-register-values --thread 1 --frame 0 N 15
58^done,register-values=[{number="15",value="0"}]
So in order to check the value of my register, I need to force a scrolling to force the debugger to load the value. So here's my question : how can I make the test scroll the view ?
If I don't do this, the execution fail when I try to select the register using this: get-view Registers | get-tree | get-item "General Registers/MY_REGISTER"
It throws me: Failed to set selection: [[General Registers, MY_REGISTER]].
I've tried to use the below code to force the discovery but it didn't worked.
with [ get-view Registers | get-tree ] {
get-item "General Registers" | expand-all
select "General Registers/MY_REGISTER" |
Re: How to scroll a view ? [message #1791541 is a reply to message #1791353] |
Mon, 02 July 2018 04:42  |
Hi Viktoria,
Thanks for your answer.
I'm a bit frustrated that there's no such commmand :-(
Edit: I've tried your method, but it doesn't work ... , my bad, I've made mistakes in my test, now it works !!
The use of the command "select" force the system to go through the whole tree to find the item to select. So it force the discovery of all the registers.
I use a first "select" inside a try-catch block because it will failed (don't know why). Then a second one (that will work since registers has been discovered now) to perform what I want to perform.
try -command { select "General Registers/MY_REGISTER" } -catch { }
select "General Registers/MY_REGISTER" | get-menu "Number Format/Hex" | click
[Updated on: Mon, 02 July 2018 08:44] by Moderator
FUDForum. Page generated in 0.04643 seconds
