Home » Modeling » ATL » Microsoft Office Excel Extractor Problem
Microsoft Office Excel Extractor Problem [message #1790932] Wed, 20 June 2018 06:30 Go to next message
I tried to run the following example:
https://www.eclipse.org/atl/atlTransformations/#MSOfficeExcelExtractor
But I am getting some error.
ATL file:
query XML2Text = XML!Root.allInstances()
		->asSequence()
		->first().ExcelFile().writeTo('exampleExcelJavaSource.xml');
helper context XML!Root def: ExcelFile() : String =
	'<?xml version="1.0"?>'+'\n'+'<?mso-application progid="Excel.Sheet"?>'+'\n'
	+ self.toString2('');
helper context XML!Element def: toString2(indent : String) : String =
	let na : Sequence(XML!Node) =
		self.children->select(e | not e.oclIsKindOf(XML!Attribute)) in
	let a : Sequence(XML!Node) =
		self.children->select(e | e.oclIsKindOf(XML!Attribute)) in
	indent + '<' + self.name +
	a->iterate(e; acc : String = '' |
		acc + ' ' + e.toString2()
	if na->size() > 0 then
		+ na->iterate(e; acc : String = '' |
			acc +
			if e.oclIsKindOf(XML!Text) then
			else
				'\r\n'
			endif
				+ e.toString2(indent + '  ')
		if na->first().oclIsKindOf(XML!Text) then
			'</' + self.name + '>'
			else
				'\r\n' + indent + '</' + self.name + '>'
		endif
	else
	endif;
helper context XML!Attribute def: toString2() : String =
	self.name + '=\"' + self.value + '\"';
helper context XML!Text def: toString2() : String =
	self.value;
Error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation toString2: wrong number of parameters
	at toString2#86(XML2Text.atl[28:7-28:33])
		local variables: self=IN!Data, indent='          ', na=Sequence {IN!<unnamed>}, a=Sequence {IN!ss:Type}, acc='', e=IN!<unnamed>
		local variables: self=IN!Cell, indent='        ', na=Sequence {IN!Data}, a=Sequence {}, acc='', e=IN!Data
		local variables: self=IN!Row, indent='      ', na=Sequence {IN!Cell, IN!Cell, IN!Cell, IN!Cell, IN!Cell}, a=Sequence {}, acc='', e=IN!Cell
		local variables: self=IN!Table, indent='    ', na=Sequence {IN!Column, IN!Column, IN!Column, IN!Column, IN!Column, IN!Row, IN!Row, IN!Row, IN!Row, IN!Row}, a=Sequence {}, acc='
      <Column ss:Width="150.0"/>
      <Column ss:Width="150.0"/>', e=IN!Row
		local variables: self=IN!Worksheet, indent='  ', na=Sequence {IN!Table}, a=Sequence {IN!ss:Name}, acc='', e=IN!Table
		local variables: self=IN!Workbook, indent='', na=Sequence {IN!Worksheet}, a=Sequence {IN!xmlns, IN!xmlns:ss}, acc='', e=IN!Worksheet
	at ExcelFile#9(XML2Text.atl[7:4-7:22])
	at main#6(XML2Text.atl[1:18-3:24])
		local variables: self=XML2Text : ASMModule
Here, the error shows, "Operation toString2: wrong number of parameters"
But I think code is okay, can you please help me?
Re: Microsoft Office Excel Extractor Problem [message #1791089 is a reply to message #1790932] Fri, 22 June 2018 13:08 Go to previous messageGo to next message
Regular ATL does not support operation overloading (same name and context, different parameters). Either choose another operation name for the different toString2() variants, or use the EMFTVM runtime.
Re: Microsoft Office Excel Extractor Problem [message #1791107 is a reply to message #1791089] Sat, 23 June 2018 04:55 Go to previous message
Thanks a lot. I will try to do this with a different name. But I was wondering, it is available in the official transformation list, so they must be tested it successfully before posting it. How did it work in that case?
Previous Topic:Output model creation and extraction problem
Next Topic:UML profile to Ecore transformation
Current Time: Sat Jul 26 12:08:12 EDT 2025
Powered by FUDForum. Page generated in 0.06880 seconds
