Home » Modeling » Eclipse Layout Kernel » [ELK] SOUTH ports and NORTH ports are overlapped
| [ELK] SOUTH ports and NORTH ports are overlapped [message #1790601] |
Wed, 13 June 2018 08:15  |
In my diagram, I have a compound node container which has several children, including its ports and children node containers. When my parent node container has SOUTH or NORTH ports, which are unconnected and have no edges, these SOUTH and NORTH ports are overlapped.
I have no idea about when these SOUTH and NORTH ports ' position are fixed. Can you give me some hints or tell me how to fix this issue?
I use this property: HierarchyHandling.INCLUDE_CHILDREN
Thanks and hope for your reply.
| Re: [ELK] SOUTH ports and NORTH ports are overlapped [message #1790925 is a reply to message #1790889] |
Wed, 20 June 2018 05:33   |
I use ELK 0.4.0 with the following properties to layout my diagram, I met an exception:
Properties:
.setProperty(CoreOptions.ALGORITHM, "org.eclipse.elk.alg.layered")
.setProperty(CoreOptions.DIRECTION, Direction.RIGHT)
.setProperty(CoreOptions.PORT_LABELS_PLACEMENT, PortLabelPlacement.INSIDE)
.setProperty(LayeredOptions.PORT_CONSTRAINTS, PortConstraints.FIXED_SIDE)
.setProperty(CoreOptions.NODE_SIZE_OPTIONS, EnumSet.of(SizeOptions.MINIMUM_SIZE_ACCOUNTS_FOR_PADDING))
.setProperty(CoreOptions.NODE_SIZE_CONSTRAINTS, EnumSet.allOf(SizeConstraint.class))
.setProperty(CoreOptions.NODE_LABELS_PLACEMENT, NodeLabelPlacement.insideTopCenter())
.setProperty(LayeredOptions.MERGE_EDGES, true).setProperty(LayeredOptions.MERGE_HIERARCHY_EDGES, true)
.setProperty(CoreOptions.HIERARCHY_HANDLING, HierarchyHandling.INCLUDE_CHILDREN);
Exception:
at org.eclipse.elk.alg.layered.p3order.AbstractBarycenterPortDistributor.updateNodePositions(AbstractBarycenterPortDistributor.java:325)
at org.eclipse.elk.alg.layered.p3order.AbstractBarycenterPortDistributor.distributePortsWhileSweeping(AbstractBarycenterPortDistributor.java:85)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepReducingCrossings(LayerSweepCrossingMinimizer.java:248)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepInHierarchicalNode(LayerSweepCrossingMinimizer.java:287)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepInHierarchicalNodes(LayerSweepCrossingMinimizer.java:266)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.sweepReducingCrossings(LayerSweepCrossingMinimizer.java:250)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.minimizeCrossingsWithCounter(LayerSweepCrossingMinimizer.java:200)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.compareDifferentRandomizedLayouts(LayerSweepCrossingMinimizer.java:185)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.lambda$1(LayerSweepCrossingMinimizer.java:131)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.minimizeCrossings(LayerSweepCrossingMinimizer.java:143)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.process(LayerSweepCrossingMinimizer.java:121)
at org.eclipse.elk.alg.layered.p3order.LayerSweepCrossingMinimizer.process(LayerSweepCrossingMinimizer.java:1)
at org.eclipse.elk.alg.layered.ElkLayered.hierarchicalLayout(ElkLayered.java:241)
at org.eclipse.elk.alg.layered.ElkLayered.doCompoundLayout(ElkLayered.java:182)
at org.eclipse.elk.alg.layered.LayeredLayoutProvider.layout(LayeredLayoutProvider.java:58)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.executeAlgorithm(RecursiveGraphLayoutEngine.java:222)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layoutRecursively(RecursiveGraphLayoutEngine.java:197)
at org.eclipse.elk.core.RecursiveGraphLayoutEngine.layout(RecursiveGraphLayoutEngine.java:76)
at org.eclipse.elk.core.service.DiagramLayoutEngine.layout(DiagramLayoutEngine.java:718)
at org.eclipse.elk.core.service.DiagramLayoutEngine.layout(DiagramLayoutEngine.java:650)
at org.eclipse.elk.core.service.DiagramLayoutEngine$1.execute(DiagramLayoutEngine.java:400)
at org.eclipse.elk.core.service.util.MonitoredOperation$1.run(MonitoredOperation.java:236)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:748)
In my source codes, I just customized my port side according to my semantic model information, and I did not changed the source codes of ELK 0.4.0.
I have found that if "LayeredOptions.PORT_CONSTRAINTS, PortConstraints.FIXED_SIDE" and "CoreOptions.HIERARCHY_HANDLING, HierarchyHandling.INCLUDE_CHILDREN" both exist, the exception will occur, Do you met this kind of problem? Did I have something wrong with my configuration or it is a bug? Please give me some suggestions.
[Updated on: Wed, 20 June 2018 05:35] by Moderator
| Re: [ELK] SOUTH ports and NORTH ports are overlapped [message #1790928 is a reply to message #1790921] |
Wed, 20 June 2018 05:53  |
Properties:
Exception:
Current Time: Mon Nov 03 15:31:09 EST 2025
Powered by FUDForum. Page generated in 0.43127 seconds
