Home » Eclipse Projects » Kura » Sending MQTT to AWS NOT WORKING
Sending MQTT to AWS NOT WORKING [message #1790749] Fri, 15 June 2018 09:44 Go to next message
I have Kura 3.2.0 installed on my Rpi.
I want to send messages generated from opcua_demo_server
to AWS IoT hub. I've been following the guide at:
https://eclipse.github.io/kura/cloud/kura-aws-cloud.html
Of course I've taken into account the 3.2.0 note but despite that the MQTT connection to AWS does not work and i receive the following error: bad certificate
Care to help me out?
Michele
Re: Sending MQTT to AWS NOT WORKING [message #1790804 is a reply to message #1790749] Mon, 18 June 2018 04:45 Go to previous messageGo to next message
could you please provide the content of kura.log and kura-console.log?
Could you also double check, using keytool, that the certificate is actually in the keystore?
Thanks.
Matteo
Re: Sending MQTT to AWS NOT WORKING [message #1790856 is a reply to message #1790804] Tue, 19 June 2018 03:17 Go to previous messageGo to next message
The error generated whenever I click on connect to AWS on the Cloud Connection tab:
2018-06-19 07:10:18,817 [qtp6417194-167] WARN  o.e.k.w.s.GwtNetworkServiceImpl - Illegal client state
java.lang.IllegalStateException: Invalid client configuration
        at org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport.setupMqttSession(MqttDataTransport.java:892)
        at org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport.connect(MqttDataTransport.java:286)
        at org.eclipse.kura.core.data.DataServiceImpl.connect(DataServiceImpl.java:493)
        at org.eclipse.kura.web.server.GwtStatusServiceImpl.connectDataService(GwtStatusServiceImpl.java:93)
        at sun.reflect.GeneratedMethodAccessor31.invoke(Unknown Source)
        at com.google.gwt.user.server.rpc.RPC.invokeAndEncodeResponse(RPC.java:587)
        at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:333)
        at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:303)
        at com.google.gwt.user.server.rpc.RemoteServiceServlet.processPost(RemoteServiceServlet.java:373)
        at com.google.gwt.user.server.rpc.AbstractRemoteServiceServlet.doPost(AbstractRemoteServiceServlet.java:62)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
        at org.eclipse.kura.web.server.OsgiRemoteServiceServlet.service(OsgiRemoteServiceServlet.java:41)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
        at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1223)
        at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:148)
        at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:62)
        at org.eclipse.equinox.http.servlet.internal.context.DispatchTargets.doDispatch(DispatchTargets.java:131)
        at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:74)
        at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:284)
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:841)
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
        at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
        at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
        at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
        at org.eclipse.jetty.server.Server.handle(Server.java:561)
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:334)
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251)
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:104)
        at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
        at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:243)
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:679)
        at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:597)
        at java.lang.Thread.run(Thread.java:748)
Re: Sending MQTT to AWS NOT WORKING [message #1790861 is a reply to message #1790856] Tue, 19 June 2018 04:57 Go to previous messageGo to next message
I've followed the procedure again from the start and the error I get is the following:
MqttException (0) - javax.net.ssl.SSLHandshakeException: Received fatal alert: bad_certificate
        at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38)
        at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:664)
Caused by: javax.net.ssl.SSLHandshakeException: Received fatal alert: bad_certificate
        at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
        at sun.security.ssl.Alerts.getSSLException(Alerts.java:154)
        at sun.security.ssl.SSLSocketImpl.recvAlert(SSLSocketImpl.java:2038)
        at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1135)
        at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385)
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413)
        at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397)
        at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:93)
        at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650)
        ... 1 more
2018-06-19 08:56:15,251 [qtp27114311-170] INFO  o.e.k.c.d.t.m.MqttDataTransport - Closing client...
2018-06-19 08:56:15,252 [qtp27114311-170] INFO  o.e.k.c.d.t.m.MqttDataTransport - Closed
2018-06-19 08:56:15,252 [pool-9-thread-1] INFO  o.e.k.c.s.r.LogStatusRunnable - Notification LED off
2018-06-19 08:56:15,252 [qtp27114311-170] WARN  o.e.k.w.s.GwtNetworkServiceImpl - Error connecting
org.eclipse.kura.KuraConnectException: "Connection failed. Cannot connect"
        at org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport.connect(MqttDataTransport.java:333)
        at sun.reflect.GeneratedMethodAccessor98.invoke(Unknown Source)
Caused by: MqttException (0) - javax.net.ssl.SSLHandshakeException: Received fatal alert: bad_certificate
        ... 1 more
        ... 1 more
Re: Sending MQTT to AWS NOT WORKING [message #1790996 is a reply to message #1790861] Thu, 21 June 2018 04:02 Go to previous messageGo to next message
I've rolled back to version 3.1.1. Please fix the known issue as soon as possible!
Re: Sending MQTT to AWS NOT WORKING [message #1792693 is a reply to message #1790996] Sun, 22 July 2018 03:03 Go to previous messageGo to next message
Hi all,
i trying out Kura 3.2.0 with AWS right now and i am experiencing exactly the same problem as described in the opening post.
Can anybody confirm this is an official issue or the other way round, that AWS CloudConnection is definitely working on Kura 3.2.0
I am using Pi 3b+
the keystore contains 2 keys, one of type trustedCertEntry from verisign and one of AWS of type PrivateKeyEntry.
Kind regards,
Hans
Re: Sending MQTT to AWS NOT WORKING [message #1792859 is a reply to message #1792693] Wed, 25 July 2018 04:38 Go to previous message
is the certificate signature the same between the files you are using and the certificate loaded in the keystore?
Matteo
Previous Topic:Can Kura work on x86 based linux system?
Next Topic:BH1705 Sensor.
Current Time: Thu Nov 06 16:45:59 EST 2025
Powered by FUDForum. Page generated in 0.04116 seconds
