Home » Modeling » EMF » Mapping dateTime(How to map a dateTime in ECore so it can be used in a GUI and in an XSD)
Mapping dateTime [message #1790522] Tue, 12 June 2018 06:51 Go to next message
Hi all,
My project uses and leverages ECore for two pipelines:
  1. Generate Java code, edit, editor code and a Sirius plugin to edit instance models of my ECore model
  2. Generate an XSD to facilitate Python users using python's generateDS program
Now my model uses currently an EDate to describe DateTime information. My problem now is that for pipeline 1: the generated Java code uses the old-fashioned Date-object instead of LocalDateTime (available in Java8). If I use a EDataType to wrap a LocalDateTime, I am not able to use the generated editors to edit the value of the field, and I am unsure how to map that datatype onto the XSD.
For pipeline 2, on the other hand, the generator converts it to an xsd:string when I do the automatic generation of an XML schema (using the XML option of the genmodel), instead of and xsd:dateTime. If I use XMLTypes in my model, the XSD does not change and does not use xsd:dateTime, but the Java code is generated using an XMLGegorianCalendar instead of a LocalDateTime, which I cannot edit in the generated editor either.
How can I solve this issue?
Is there planned support for LocalDateTime in EMF?
Thanks!
Ewoud
Re: Mapping dateTime [message #1790527 is a reply to message #1790522] Tue, 12 June 2018 08:06 Go to previous messageGo to next message
No, there are no plans to support LocalDateTime. It's always possible to create your own EDataType to support any Java class for which you can support conversion to and from a string representation. When you used your own EDataType to wrap LocalDateTime, did you modify the generated factory to implement the createXyzFromString/convertXyzToString method? Certainly the XML Types, e.g., dateTime, are editable in a generated editor; they're edited via their string representation. These two new features of EMF 2.14 (part of this month's Photon release) might be of interest:
https://wiki.eclipse.org/EMF/Recipes#Recipe:_Generating_data_types_that_support_date.2Ftime_format
https://wiki.eclipse.org/EMF/Recipes#Recipe:_Use_Nebula-based_Cell_Editors_to_Modify_Date.2FTime_Properties
Re: Mapping dateTime [message #1790765 is a reply to message #1790527] Fri, 15 June 2018 17:25 Go to previous messageGo to next message
Hi Ed,
Thanks for your fast reply. The extensions look promising! I'll have a look when the stable version of Photon is released at the end of the month.
I did check the createXyzFromString() methods, but that only works in a deployed plugin that uses the generated/adapted factory, but not when using the dynamic instances that I am currently using to do fast model development (BTW a very nice feature). That's why I hoped for internal support for LocalDateTime.
Just curious: Is the 'new' java Time API not supported, because it is in JDK8 and not in JDK5? Or is there another reason?
Re: Mapping dateTime [message #1790766 is a reply to message #1790765] Fri, 15 June 2018 17:37 Go to previous messageGo to next message
I was not even aware this existed.
Re: Mapping dateTime [message #1790808 is a reply to message #1790766] Mon, 18 June 2018 05:26 Go to previous message
If you need to deal with time, its awesome! It makes time handling in Java so much better than using the crippled Date/Calendar implementation. See for an intro here: http://www.baeldung.com/java-8-date-time-intro
Previous Topic:Dynamic Enumeration-based Attributes
Next Topic:Problem Reloading Genmodel. `<>` operator is not allowed for source level below 1.7
Current Time: Mon Jul 21 05:57:39 EDT 2025
Powered by FUDForum. Page generated in 0.07563 seconds
