Home » Modeling » Papyrus » java final, @Override keywords
java final, @Override keywords [message #1790495] Mon, 11 June 2018 16:09 Go to next message
Are there any stereotypes from ant profiles that will allow the java code generation to add the 'final ' keyword.
In a similar way, is there any way to get any of the java annotations generated, eg @Override, @Nullable.
Steve
Re: java final, @Override keywords [message #1790753 is a reply to message #1790495] Fri, 15 June 2018 11:18 Go to previous message
The final keyword is supported for different elements.
In case of an attribute or a method, it can be controlled via the UML "isLeaf" property. Note that this property is somewhat hidden as it is only visible in Papyrus "Advanced" dialog,
The Java profile have a stereotype called "Final" which can be applied to a parameter.
As far as I know, Java annotations are currently not supported
Previous Topic:Need Help: what is the best approach to remove some UML elements from palette/menus?
Next Topic:Papyrus does not recognize the types from an UML Profile
Current Time: Sun Jul 20 20:28:12 EDT 2025
Powered by FUDForum. Page generated in 0.28035 seconds
