Home » Eclipse Projects » Eclipse Scout » How to call stored procedure with output parameters
How to call stored procedure with output parameters [message #1790651] Wed, 13 June 2018 18:57 Go to next message
Hi.
I'm beginner in Scout framework and I have one trouble.
I have stored procedure in Oracle Database with this header:
procedure create_user(
     av_name varchar2
    ,av_surname varchar2
    ,av_mail varchar2
    ,an_bank_code varchar2
    ,av_password varchar2
    ,an_return_code out number
    ,av_return_code_desc out varchar2)
I need call this procedure in UserDetailService.java:
long ret = 0;
String retDesc = "";
SQL.callStoredProcedure("call app.user_manager.create_user(:name, :surname, :loginName, :bankCode, :password, :ret, :retDesc)",
				new NVPair("name", formData.getName().getValue()),
				new NVPair("surname", formData.getSurname().getValue()),
				new NVPair("loginName", formData.getLoginName().getValue()),
				new NVPair("bankCode", formData.getInstitution().getValue()),
				new NVPair("password", formData.getPassword().getValue()),
				new NVPair("ret", ret),
				new NVPair("retDesc", retDesc));
Procedure work fine, but not return values to "ret" and "retDesc" variables.
Can anyone advise me? Thank you very much.
Re: How to call stored procedure with output parameters [message #1790654 is a reply to message #1790651] Thu, 14 June 2018 01:13 Go to previous messageGo to next message
Hi there
TL;DR: Use holders for output values (subclasses of org.eclipse.scout.rt.platform.holders.IHolder<T>)
Longer answer:
You pass in a primitive long and a reference to a String for the two output parameters.
Because Java is call-by-value, the NVPair just receives a reference to an (immutable) String object, and a copy of the long value. With both of them, it can't return the result values to you.
The solution to this is a holder. A Holder is an object that is a mutable container for the result which you can pass to the NVPair to get returned values.
Holders exist in many forms, but these all implement the IHolder interface (org.eclipse.scout.rt.platform.holders):
  • For most Java Primitives (DateHolder, StringHolder, IntegerHolder, ..) and their respective Array Versions (StringArrayHolder, ...)
  • Properties in FormData (AbstractPropertyData)
  • ValueFields in FormData (AbstractValueFieldData)
Pass any of them to your NVPair and that should do the trick.
[Updated on: Thu, 14 June 2018 01:17] by Moderator
Re: How to call stored procedure with output parameters [message #1790713 is a reply to message #1790654] Thu, 14 June 2018 14:38 Go to previous message
Thank you very much, it's work.
Previous Topic:Auditing Source - Eclipse Oxygen with Scout
Next Topic:[Oxygen] How does CSS/Less Styling work?
Current Time: Tue Sep 16 23:34:30 EDT 2025
Powered by FUDForum. Page generated in 0.25414 seconds
