Home » Modeling » VIATRA » Querying FeatureMap constructs ?
Querying FeatureMap constructs ? [message #1789953] |
Fri, 01 June 2018 03:44  |
 Messages: 23 Registered: September 2015 |
Hello !
I was wondering whether querying a model containing EMF feature maps was possible ?
I got one, not created by my hands, but generated from XSD2Ecore importer.
My first tries were unsuccessful :
- I'm unable to navigate down features typed EFeatureMapEntry : no way to access key or value
- The objects stored in a containment branch beneath a FeatureMap are not considered even with a simple unary type pattern
By the way, I was quite happy that the generated derived features created for each kind of element in the feature map are well-behaving.
I could conclude that FeatureMap are not fully supported by Viatra queries, am I right ?
--Eric
Re: Querying FeatureMap constructs ? [message #1790130 is a reply to message #1789958] |
Tue, 05 June 2018 11:18   |
Hi Zoltán,
According to the example in the EMF document here: https://www.eclipse.org/modeling/emf/docs/overviews/FeatureMap.pdf
preferredOrders and standardOrders are the two derived features, orders is the EFeatureMapEntry containment attribute.
Let's imagine a root Model element classically containing suppliers.
As expected:
matches the model and each of its owned suppliers
matches all the Supplier objects
Using derived features:
Supplier.preferredOrders(s, po); matches suppliers and their preferred orders, meaning that the generated implementation is well behaving. Great !
As the global orders list is not usable, I could write an OR pattern combining all the derived features.
=> For the sake of simplicity, we could imagine Viatra Query to give the same matches when querying an EFeatureMapEntry[0..*] attribute: some kind of:
Supplier.orders.value(s, po); but I guess nor orders nor value would notify any change.
On the dark side of the FeatureMap:
doesn't match any object, that's the case I mentioned as being contained beneath a feature map. The containment is not a classical composition, but the composition of EFeatureMapEntry-ies containing PurchaseOrder-s as their value java property.
PurchaseOrder.anotherFeature(po, sth); wouldn't match anything. I can only suppose that it's because no PurchaseOrder is found, as stated in the previous point.
=>These two last points definitely make Viatra Query unefficient with feature maps.
Hope this helps to clarify the problem.
Please tell me if you want me to write a bug report.
--Eric
[Updated on: Tue, 05 June 2018 11:19]
Re: Querying FeatureMap constructs ? [message #1790137 is a reply to message #1790130] |
Tue, 05 June 2018 14:27   |
Hi Eric,
thanks for the more detailed description, it is somewhat clearer to me what your issue is. Yes, given VIATRA does not allow you to specify edges around EFeatureMaps; I'd go with the or pattern construct you have mentioned earlier as a workaround. I'd mention that you could create a library (basically a separate file with these queries), so you don't have to pollute your main query definitions with these helper patterns.
The second case on the other hand clearly feels like a major issue in VIATRA that we should fix as soon as possible. Given the way the issue manifests itself, I believe you are using an older version of VIATRA (older than 1.6), because in newer versions with default settings Suppliers.preferredOrders(s, o) should also not return anything if PurchaseOrder(o) result in an empty match set as well.
A bug report would really be helpful; and if you could at least point us to a metamodel that has such a problematic construct included that would help a great deal of finding the issue in our codebase, as we would not need to create a domain that demonstrates the issue before we could check anything. Looking at the domains I am familiar with I did not find any containment-based feature map usage like this.
Thanks again for the detailed explanation and your willingness to help,
Zoltán
Re: Querying FeatureMap constructs ? [message #1790514 is a reply to message #1790472] |
Tue, 12 June 2018 04:47  |
Hi Eric,
it would be very helpful if you could provide a public example where VIATRA is failing in the way you described, because the issue seems to be difficult to reproduce.
Specifically, I started from the usual library.xsd example, and wrapped the 'books' and 'writers' containment references into an xsd:choice. Viatra Query seemed to work well (or at least the v2.0 RC that I tried it with, though I do not expect that this functionality was impacted between 1.5 and 2.0).
Just a stray thought: is it perhaps possible that in your orders example, the `preferredOrders` EReference is, mistakenly, not set as containment, and therefore the referred PurchaseOrder object could be out of the EMFScope that was defined for your query engine?
thanks,
Gábor
Current Time: Fri Jul 25 10:01:16 EDT 2025
Powered by FUDForum. Page generated in 0.32487 seconds
