Home » Eclipse Projects » WindowBuilder » WB not working in Linux and Windows 7 + Photon 4.8.0RC1
WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1787586] Tue, 29 May 2018 12:23 Go to next message
maybe the problem is only due to the undergoing work on the Photon Eclipse Train, but just in case I would like to make it known.
I am testing WB (1.9.0, from IDE Marketplace) on latest Photon build
Eclipse IDE for RCP and RAP Developers
Version: Photon Release Candidate 1 (4.8.0RC1)
Build id: 20180524-1423
OS: Linux, v.4.15.0-22-generic, x86_64 / gtk 3.22.30, WebKit 2.20.2
Java version: 1.8.0_171
Linux=Ubuntu LTS 18.04 / GNOME
Windows=Windows 7
but when I try to open a view I see an empty area while the Error Log shows:
Unhandled event loop exception
	at org.eclipse.wb.internal.core.editor.UndoManager.addSelectionListener(UndoManager.java:187)
	at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:382)
	at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
	at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:263)
	at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:241)
	at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
	at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
	at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5686)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1370)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1396)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1379)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1164)
	at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3195)
	at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1878)
	at org.eclipse.swt.custom.CTabFolder.lambda$0(CTabFolder.java:328)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4940)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4518)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1170)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1059)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
	at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:683)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:597)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:656)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:592)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1498)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1471)
Is there some others having the same issue?
Thank you very much
Vincenzo
[Updated on: Wed, 30 May 2018 06:43] by Moderator
Re: WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1790031 is a reply to message #1787586] Sun, 03 June 2018 13:01 Go to previous messageGo to next message
I'm not answering your question, but rather using it to make a non-related point.
File "UndoManager.java" is _not_ in the Git repository that [supposedly] contains the WindowBuilder source code. Why is that?
Re: WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1790070 is a reply to message #1787586] Mon, 04 June 2018 07:47 Go to previous messageGo to next message
Got the same problem. Did you open a bug?
Re: WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1790225 is a reply to message #1790070] Thu, 07 June 2018 05:15 Go to previous messageGo to next message
I opened it now
https://bugs.eclipse.org/bugs/show_bug.cgi?id=535642
please integrate with any additional info you may have.
Thank you
Vincenzo
Re: WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1790273 is a reply to message #1790031] Thu, 07 June 2018 13:24 Go to previous messageGo to next message
Avi Abrami wrote on Sun, 03 June 2018 19:01
Hi Avi,
I cloned WB source code from its Git repository (see also https://www.eclipse.org/forums/index.php/t/1093240/)
which is the following
git://git.eclipse.org/gitroot/windowbuilder/org.eclipse.windowbuilder.git
and I can assure that file "UndoManager.java" is there (see image)
index.php/fa/33042/0/
You'll see it also here:
https://git.eclipse.org/c/windowbuilder/org.eclipse.windowbuilder.git/tree/org.eclipse.wb.core.java/src/org/eclipse/wb/internal/core/editor
Are you cloning from the same Git repository?
  • Attachment: WB-class.png
    (Size: 226.56KB, Downloaded 2735 times)
[Updated on: Thu, 07 June 2018 13:31] by Moderator
Re: WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1790431 is a reply to message #1790273] Sun, 10 June 2018 14:59 Go to previous messageGo to next message
Thank you Vincenzo.
Your screen shot led me to discovering how to correctly download the WindowBuilder source code.
Thanks!
Re: WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1790735 is a reply to message #1787586] Fri, 15 June 2018 04:22 Go to previous messageGo to next message
Hi all,
I tested latest Photon release
Version: Photon Release Candidate 3 (4.8.0RC3)
Build id: 20180607-0625
OS: Linux, v.4.15.0-23-generic, x86_64 / gtk 3.22.30
with latest WB release 1.9.1.201806150629
taken from
http://download.eclipse.org/windowbuilder/WB/integration/4.8
but the problem on Linux (I am using Ubuntu 18.04) is still there (the IDE crashes as soon as I try to open the WB Design view).
Bug was also posted here
@WB Project Team: is there something I can do on my environment to make WB work on Linux?
@WB Users on Linux: are you having the same problem? If otherwise it works for you, can you provide details on your Linux environment (distro, version, desktop environment, ..)?
Thank you very much
Vincenzo
Re: WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1790854 is a reply to message #1790735] Tue, 19 June 2018 03:07 Go to previous messageGo to next message
Try version 1.9.1 http://download.eclipse.org/windowbuilder/WB/integration/4.8/
Re: WB not working in Linux and Windows 7 + Photon 4.8.0RC1 [message #1790857 is a reply to message #1790854] Tue, 19 June 2018 03:21 Go to previous message
I updated the marketplace entry.
Previous Topic:Windowbuilder design tab problem
Next Topic:WindowBuilder Crashes
Current Time: Fri Jul 25 11:11:05 EDT 2025
Powered by FUDForum. Page generated in 0.06276 seconds
