Home » Modeling » TMF (Xtext) » Generate code with Xtend of ReqIF model
Generate code with Xtend of ReqIF model [message #1790296] Fri, 08 June 2018 02:45 Go to next message
i want to write a code generator with Xtend on a Non-Xtext model based on this tutorial.
But I have problems understanding the part where to reference the model I want to gernerate code.
In detail: I want to generate code of a ReqIF model (org.eclipse.rmf.reqif10).
Where do I have to reference this model?
Re: Generate code with Xtend of ReqIF model [message #1790297 is a reply to message #1790296] Fri, 08 June 2018 02:50 Go to previous messageGo to next message
i am not sure if i understand your problem. you should have some plugins installed in your eclipse that provide that metamodel so you can add these as dependency to your manifest
Re: Generate code with Xtend of ReqIF model [message #1790301 is a reply to message #1790297] Fri, 08 June 2018 03:29 Go to previous messageGo to next message
When you properly set up the resource services as described, your model will be contained in the Resource instance that is passed to the IGenerator implementation. Of course you need some understanding of EMF, which is also used by org.eclipse.rmf.
Re: Generate code with Xtend of ReqIF model [message #1790342 is a reply to message #1790301] Fri, 08 June 2018 08:31 Go to previous messageGo to next message
I added the plugins to the dependencies that's not the issue.
I do not understand how to
I think, i have to do that on the workflow with "registerGenerateEPackage = ..." but which packages do I have to register? Well, obviously the package of the plugin(s), but where do I get the names from?
Re: Generate code with Xtend of ReqIF model [message #1790343 is a reply to message #1790342] Fri, 08 June 2018 08:35 Go to previous messageGo to next message
the package of your metamodel.
e.g.
org.eclipse.rmf.reqif10.ReqIF10Package
Re: Generate code with Xtend of ReqIF model [message #1790347 is a reply to message #1790343] Fri, 08 June 2018 09:24 Go to previous message
A nice presentation about building Code Generators for Non-Xtext Models with Xtend is available under https://www.youtube.com/watch?v=teOULtQ81-U
Previous Topic:How to fetch value from my text
Next Topic:Antlr4 to xtext
Current Time: Mon Jul 21 03:30:24 EDT 2025
Powered by FUDForum. Page generated in 0.29365 seconds
