Ecore: Type parameter for interface implementation? [message #1787631] |
Wed, 30 May 2018 06:14  |
Dear all,
What I try to accomplish in the first place, is having an Ecore model where its instances are able to link to classes that all implement the same interface.
As it does not seem to be possible to use the feature "Operation" for that (so that every instance of an Eclass has its own implementation and can be serialized), I tried to have these methods in classes and than have an Eclass in the Ecore which points to a respective Java class.
What I managed to do using the "ETypeParameter" function is to generate something like this:
public interface ESem<ISem> extends EObject {
ISem is the interface all Sem Java classes do implement. But of course, I cannot put a class SemA which implements ISem not into ESem, because the type of SemA is not <ISem> but <SemA extends ISem>.
So, is there a way to model the Ecore model respectively so that the following code is generated
public interface ESem<T extends ISem> extends EObject {
Re: Ecore: Type parameter for interface implementation? [message #1787635 is a reply to message #1787632] |
Wed, 30 May 2018 07:20   |
Thanks for your quick reply,
Ed Willink wrote on Wed, 30 May 2018 06:40Hi
The GenModel Root extends/implements Class/Interface options seem to do what you are looking for. Can you explain why they don't work for you?
And, can you explain your problem much more clearly. I'm not clear what you mean by the feature "Operation" or why it might help solve your problem.
With "operation" I mean the function of adding an operation (i.e. method) to an Eclass. This apparently cannot solve my problem because one Eclass can only have one implementation which then also is not part of the model instantiation.
Basically, I want to combinate to things:
1. some kind of domain model (as Ecore) that manages knowledge and processes how to manipulate a number of given data sources and under which circumstances.
2. a number of Java classes which implement behaviour that is needed for (parts of) the data manipulation code from 1.
In the example, the classes mentioned in 2. all implement the interface ISem.
So my idea is to have an Eclass which points to a Java class. This should generally be possible adding an attribute with the predefined datatype "EJavaClass".
So I added a Eclass "ESem" to the model including an attribute "mySem: EJavaClass".
But this lets Eclipse generate code with a generic property "Class", which lets it point to virtually any valid Java class.
I want to restrict this so that only classes can be used that implement the interface ISem.
I thought that defining a type parameter (i.e., shown as the light gray dashed box attached to an Eclass in the Ecore diagram editor) would be the way to go, but that leads to generated code defining
This doesn't help because a class, be it "SemA" which implements ISem does not have the type ISem but matches , right?
So what I want to know: is there a way to get to this variant, and which modifications I need to make to the Ecore?
Regarding the genmodel options you mentioned: this would apply to all classes in the Ecore model, right?
Re: Ecore: Type parameter for interface implementation? [message #1790541 is a reply to message #1790277] |
Tue, 12 June 2018 11:18   |
Ed Merks wrote on Thu, 07 June 2018 14:44DanglingHREFException is answered in the FAQ and has nothing to do with using generics:
Correct. As I wrote, the original problem is solved now but the DanglingHREFException is a new problem I face when trying to save the model.
EJavaClass instances already support serialization,
so I'm not sure what problem you're having with that.
The problem apparently is that the classes (in my example, a number of classes with the type <? extends ISem>) I have are not part of the resource.
I understand that this is because they are not part of the Ecore model but only referenced by "mySem" attributes.
If I understand the FAQ you mentioned right, only EObjects can be and need to be added to the resource, but the classes I want to refer to are pure Java classes.
The model code generated for the My.ecore from my last post also generates pure Java class attributes and no EJavaclass:
public class SemImpl extends MinimalEObjectImpl.Container implements Sem {
* The cached value of the '{@link #getMySem() <em>My Sem</em>}' attribute.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @see #getMySem()
* @generated
* @ordered
protected Class<? extends ISem> mySem;
So, the questions are:
1) Is it possible to have a Ecore model reference pure Java classes and persist it? What actions need to take place then so that the classes are part of the resource and no DanglingHREFException comes up?
2) If not, what changes need to be made to be made to the Ecore/the classes then?
Re: Ecore: Type parameter for interface implementation? [message #1794661 is a reply to message #1790576] |
Tue, 04 September 2018 11:55  |
Thank you for your replies. I'm not sure if I understood every detail correctly, but I got more convinced that trying to solve my problem fully and directly with EMF may have been an impractical wish in the first place.
Finally, I solved my problem as follows:
The "Sem" class got a String attribute as identifier.
Then, an arbitrary number of Java classes implements the Sem-interface.
I then added an extension point to my project and the classes make use of this extension point.
Thus, during run time, I can query the registration and get all implementations and identify them via their identifier attribute as defined in the EMF metamodel.
FUDForum. Page generated in 0.04794 seconds
