Home » Modeling » Epsilon » Executing an ant build file programmatically which, in turn, executes an etl transformation
Executing an ant build file programmatically which, in turn, executes an etl transformation [message #1787370] |
Thu, 24 May 2018 04:09  |
Dear all,
I am trying to programmatically execute an ant build file which, in turn, executes an etl transformation (from UML to a dsl in ecore).
I report in the following a minimal excerpt of the project within the build file (please notice that several other taskdef are defined and invoked, i.e. epsilon.emf.register, epsilon.emf.loadMode and epsilon.storeModel, which are not reported because they work well):
<target name="loadModels">
<taskdef name="epsilon.etl" classname="org.eclipse.epsilon.workflow.tasks.EtlTask">
<classpath>
<pathelement location=".../lib/epsilon-1.4-workflow-emf.jar"/>
<pathelement location="/.../lib/epsilon-1.4-workflow.jar"/>
<pathelement location=".../plugins/org.eclipse.epsilon.eol.engine_1.4.0.201611012202.jar"/>
<pathelement location=".../plugins/org.eclipse.epsilon.etl.engine_1.4.0.201611012202.jar"/>
<pathelement location=".../plugins/org.eclipse.epsilon.common_1.4.0.201611012202.jar"/>
<pathelement location=".../ plugins/org.eclipse.epsilon.erl.engine_1.4.0.201611012202.jar"/>
</classpath>
</taskdef>
</target>
<target name="targetModels" depends="loadModels">
<epsilon.etl src=".../transformation.etl" >
<model ref="UML"/>
<model ref="target" />
</epsilon.etl>
<epsilon.storeModel model="target"/>
</target>
Minimal code for executing the ant build above is reported in the following:
File file = new File(buildXmlFileFullPath);
Project project = new Project();
project.init();
DefaultLogger logger = new DefaultLogger();
project.setProperty("ant.file", file.getAbsolutePath());
project.addBuildListener(logger);
project.fireBuildStarted();
ProjectHelper helper = ProjectHelper.getProjectHelper();
project.addReference("ant.projectHelper", helper);
helper.parse(project, file);
project.executeTarget(target);
The etl transformation starts as follows:
pre {
"Transforming UML model TO target model ".print();
var profiler : new Native('org.eclipse.epsilon.eol.tools.ProfilerTool');
profiler.start('BatchProgram');
Here is what I obtain by executing the java code:
[epsilon.etl - transformation.etl] Line: 2, Column: 50, Reason: mismatched input: ';'
As a result, I obtain an empty target model resulting from the epsilon.storeModel task that follows epsilon.etl in the ant build file (notice that the ant is built successfully). Hence, the transformation is not executed probably due to some parsing issues.
Could anyone please help on this? Many thanks in advance.
Davide.
Re: Executing an ant build file programmatically which, in turn, executes an etl transformation [message #1787542 is a reply to message #1787483] |
Mon, 28 May 2018 09:34   |
Dear Dimitris,
thank you for your reply.
After preparing a minimal example, I figured out that the latter works. Probably my problem was related to classpath and it will emerge again when I will integrate the standalone example in my main project.
However, now I am facing another problem, i.e. I cannot load MARTE profile programmatically. In fact, as you can see in the minimal example here attached, both the two output files from the etl transformation are created (i.e. the target model and the trace model), but they are not properly filled due to the fact that the operation called at line 46 of the etl transformation rule, i.e. getUseCases(), looks for UML UseCases with <<GaScenario>> MARTE GQAM stereotype applied; this should mean that the MARTE profile is not properly loaded. Could you please help me on this, although it is not strictly related to Epsilon?
thank you in advance and best regards,
Davide
Re: Executing an ant build file programmatically which, in turn, executes an etl transformation [message #1790158 is a reply to message #1789959] |
Wed, 06 June 2018 05:36   |
Hi guys,
I am now facing the former problem I have pointed out in this topic, since I am trying to integrate the minimal example into my main project.
All the needed resources and dependencies have been copied within the main project, but I'm still getting the following error at the beginning of my etl file:
[epsilon.etl - <transformation name>.etl] Line: X, Column: Y Reason: mismatched input: ';'
Please notice that I am running 2 etl transformations via Java and I am getting the error above in both cases. Hence, you can assume that my etl files are well-formed (even because I already tested them in a standalone ad-hoc project). This should mean that the problem is related to some libraries; however, every library needed is included in the classpath/dependencies of the main project. Basically, it seems to me that it is trying to parse etl files with an incorrect epsilon parser. Note that I am not launching etl transformations through EtlModule, but through specific ant scripts invoking the epsilon.etl ant task (which has been properly defined as extension in the plugin.xml file).
Any suggestion? Please note that providing a minimal example for this problem would probably mean providing my main project, but this would be unpracticable. On the other hand, creating a minimal example for transformation invocation only would result in a project without problems (as I did before).
Re: Executing an ant build file programmatically which, in turn, executes an etl transformation [message #1790181 is a reply to message #1790161] |
Wed, 06 June 2018 11:10   |
Hi Dimitris,
it is due to the size of the code. The main project is very large, as it contains several other functionalities.
I think my problem is in someway similar to this:
https://www.eclipse.org/forums/index.php/t/1070315/
However, I'm not running the etl transformation via Java, but via ant that uses epsilon ant tasks.
I would remark that, only the epsilon.etl ant task fails, whereas all the other epsilon ant tasks are
correctly executed.
In addition, please find attached:
- a screenshot of all the plugin dependencies of my main project.
- a screenshot of the java build path libraries of my main project.
- a screenshot of all the extensions defined by my main project, with emphasis on epsilon ant tasks.
Could it be that one of those imported jars overwrite the correct antlr?
Thank you for your help, best regards,
Davide
Re: Executing an ant build file programmatically which, in turn, executes an etl transformation [message #1790230 is a reply to message #1790182] |
Thu, 07 June 2018 05:57   |
Hi guys,
I would let you know that I have solved my problem.
As supposed, some dependencies of my main project were using an old version of ant runtime, taking priority over the one I selected.
In particular, I had some dependencies to the 1.3.0 version of epsilon eol, evl, and common. I removed those dependencies and everything started to work properly :)
Thank you for your time and support.
Davide
Current Time: Fri Jul 25 23:02:53 EDT 2025
Powered by FUDForum. Page generated in 0.30574 seconds
