Home » Newcomers » Newcomers » Where to suggest EE4J JPA documentation enhancements
Where to suggest EE4J JPA documentation enhancements [message #1789912] Thu, 31 May 2018 13:45 Go to next message
I noticed that JPA implementation treat `0` passed to `Query.setMaxResults(int)` as unlimited result which makes sense since negative values cause an `IllegalArgumentException` and fetching 0 results means that the query has no purpose. However, the documentation on the interface doesn't mention this use of `0`, so that I'd like to propose it to go into a future API release.
Please note that I'm not looking to discuss my proposal here unless it's clearly non-constructive. The question is where to report the request.
-Kalle
[Updated on: Thu, 31 May 2018 14:57] by Moderator
Re: Where to suggest EE4J JPA documentation enhancements [message #1789954 is a reply to message #1789912] Fri, 01 June 2018 03:50 Go to previous messageGo to next message
I believe you're referring to the implementation provided by EclipseLink. There project page is https://www.eclipse.org/eclipselink/ and the "More" Nav menu has instructions for checking out the source and for contributing. Perhaps the project already supports Gerrit contributions. You can ask for more details on their specific forum: https://www.eclipse.org/forums/index.php?t=thread&frm_id=111
Re: Where to suggest EE4J JPA documentation enhancements [message #1789982 is a reply to message #1789954] Fri, 01 June 2018 10:33 Go to previous messageGo to next message
No, I mean the Java Persistence _API_ since this is the one people are accessing the methods through. If the change isn't done in the API, it's of no use for this case. Note that I'm aware of the fact that this is not a critical bug or anything and I'm not seeking support, I really just want to contribute an improvement. It has to be to the API documentation/interface specification, though, which would than be implemented by all implementations (including EclipseLink) for the next 9.x or 10.x release.
Re: Where to suggest EE4J JPA documentation enhancements [message #1789989 is a reply to message #1789982] Fri, 01 June 2018 12:04 Go to previous message
I don't know the structure of that new project very well. There's https://projects.eclipse.org/projects/ee4j and from there you might try using the mailing list linked from https://projects.eclipse.org/projects/ee4j/contact
Previous Topic:How to use Matlab and Eclipse Simultaneously?
Next Topic:Eclipse Oxygen - print to file
Current Time: Sun Jul 20 23:41:29 EDT 2025
Powered by FUDForum. Page generated in 0.29745 seconds
