Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] Generic Editor and RAP
[EMF Forms] Generic Editor and RAP [message #1789877] Thu, 31 May 2018 05:40 Go to next message
Hi Everyone,
have been using EMF Forms and its generic editor with great joy for last couple of months. Now I got curious if I can make a RAP version of my Generic editor adaptation. I have found this twitter post saying it should run in RAP:
https://twitter.com/jayjaybillings/status/747800829005012992
However, after a couple of hours of struggle, I gave up, but mostly due to my inexperience in RAP.
As I am using version 1.15 of EMF Forms, I was hoping for a couple if hints:
- has anyone tried this? Maybe there are some pointers to examples?
- in the bug / feature list of EMF Forms I have seen some "remove dependency to..." tasks which could be RAP related. Is the 1.15 version perhaps too old, and the same experiment could be better done with a newer version?
Thanks, and best regards!
Nikola
[Updated on: Thu, 31 May 2018 06:13] by Moderator
Re: [EMF Forms] Generic Editor and RAP [message #1789952 is a reply to message #1789877] Fri, 01 June 2018 03:31 Go to previous messageGo to next message
Hi Nikola,
most of the code should work out of the box, i.e. everything inside the editor. If you look at the GenericEditor class, you will see, that this is not a lot of code, it basically puts things together.
However, the GenericEditor itself has direct workspace dependencies, as it loads a file. This part probably needs to be adapted for the RAP use case.
If you can fill in the data another way, there should not be too much work adapting the editor class, in this case, you need to override the way, that the file is loaded and stored.
Do you have a "online" workspace in your application, which also allows to select files?
Jonas
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms] Generic Editor and RAP [message #1789961 is a reply to message #1789952] Fri, 01 June 2018 04:55 Go to previous messageGo to next message
Hi Jonas,
in my use-case, opening a single predefined file (XMI or XML) resource would be enough.
(RAP noob warning): Guessing that workspace dependencies are not available in RAP, would Generic Editor dependencies not cause problem when loading? Then maybe creating a fork would make more sense than overriding?
That could result in GenericRAPEditor end GenericRCPEditor...
[Updated on: Fri, 01 June 2018 04:56] by Moderator
Re: [EMF Forms] Generic Editor and RAP [message #1790022 is a reply to message #1789961] Sun, 03 June 2018 06:34 Go to previous message
Update:
with version 1.15, I checked out the editor project and played around a bit. At the moment I am stuck with:
Unresolved requirement: Require-Bundle: org.eclipse.emfforms.swt.treemasterdetail; bundle-version="[1.15.0,1.16.0)"
-> Bundle-SymbolicName: org.eclipse.emfforms.swt.treemasterdetail; bundle-version="1.15.0.20171220-1057"; singleton:="true"
org.eclipse.emfforms.swt.treemasterdetail [127]
Unresolved requirement: Require-Bundle: org.eclipse.emf.edit.ui; bundle-version="[2.10.0,3.0.0)"
After checking the git log for the TreeMasterDetail bundle (remove bundle dependency on org.eclipse.emf.edit.ui):
https://git.eclipse.org/c/emfclient/org.eclipse.emf.ecp.core.git/commit/bundles/org.eclipse.emfforms.swt.treemasterdetail/META-INF/MANIFEST.MF?id=e9d40d8707fd94df23e5a0bff1acca1c8e47d1cb
Similar approach is suggested here (changing bundle dependencies for import-package declarations):
https://www.youtube.com/watch?v=Z2PNgxJQK9c
I wil try to make it work with the current master version and report the results.
Previous Topic:[EMF Forms] What happened to the JavaFX renderer between version 1.7.2 and 1.8.0?
Next Topic:how to display eStructuralFeatures based on certain condition
Current Time: Mon Jul 21 00:14:49 EDT 2025
Powered by FUDForum. Page generated in 0.06184 seconds
