Home » Eclipse Projects » GEF » Displaying multiple resources in editor area
Displaying multiple resources in editor area [message #178701] Thu, 21 April 2005 11:21 Go to next message
Originally posted by: sbelgaon.progress.com
All,
I would like to display different resources in 2 section of an editor (as
opposed to the conventional tab approach for all resources - each resource
in a tab of editor) . In the top section I would like to display resources
that use graphical editor. In the botton section I would like to display
text resource editors.
If there are multiple resources that need graphical editor then I want
them to be tabbed but in the top section. Similarly if there are multiple
resources that need text editor then I want them to be tabbed but in the
bottom section.
e.g. I have seen similar examples for modeling tools where the graphical
model is displayed at the top (resource e.g - a XMI resource) and the
botton section displays the generated source from the model (resource e.g.
- .java files etc..)
Any help on how to do this is appreciated.
Sunil.
Re: Displaying multiple resources in editor area [message #178759 is a reply to message #178701] Thu, 21 April 2005 16:56 Go to previous messageGo to next message
All Eclipse users can already do this manually. You can split the editor
area by dragging the editors.
If you want two different views of the same file visible at the same time
(kinda like a split view), look at how VEP does that.
http://www.eclipse.org/vep
"Sunil Belgaonkar" <sbelgaon@progress.com> wrote in message
news:1114fe2fe21235bec0b6d11b9686f0ad$1@www.eclipse.org...
> All,
> bottom section.
> Regards,
> Sunil.
Re: Displaying multiple resources in editor area [message #178861 is a reply to message #178701] Fri, 22 April 2005 16:02 Go to previous messageGo to next message
Reusing the Java editor is going to be very difficult. See bug 46207.
> All,
> bottom section.
> e.g. - .java files etc..)
> Regards,
> Sunil.
Re: Displaying multiple resources in editor area [message #180154 is a reply to message #178759] Tue, 03 May 2005 15:26 Go to previous messageGo to next message
Can this be done using an API?
I am looking to do option 1 above.
>> All,
>> bottom section.
>> Regards,
>> Sunil.
Re: Displaying multiple resources in editor area [message #180205 is a reply to message #180154] Tue, 03 May 2005 16:02 Go to previous message
news:9cbd3b33f1c16dedd6ef5d915f2d9131$1@www.eclipse.org...
editor
Probably. This does not fall in the GEF domain. Ask on the platform
newsgroup.
time
> >> All,
(as
resource
resources
display
multiple
the
> >> bottom section.
graphical
e.g.
> >> Regards,
> >> Sunil.
Previous Topic:Glasspane
Next Topic:HELP: java.lang.IllegalStateException: Workspace is closed.
Current Time: Thu Nov 06 13:56:07 EST 2025
Powered by FUDForum. Page generated in 0.04456 seconds
