Home » Language IDEs » Java Development Tools (JDT) » Lost autocompletion mode in editor
Lost autocompletion mode in editor [message #178747] Tue, 21 September 2004 12:44 Go to next message
Originally posted by: list.eclipse.newgenesys.com
I am running Eclipse 3.0 build 200406251208 on Linux Fedora core 1. Sometime
ago I lost the autocompletion feature in the Java Editor. Not sure if the
term is right, but this feature would pop up a window suggesting the most
appropriate method when starting typying away its name. Now I have to rely
on F3 to look at the declaration. I would love to have this feature back.
I have looked everywhere I could think of, but cannot find a flag to restore
it. Also strangely some menu labels have lost their value. It is now
replaced by its tags. For example, under Run I have now
%ToggleBreakpointAction.label and things like that.
I suspect I must be missing a resource file, but which one?
Thanks for your help
Pascal
Re: Lost autocompletion mode in editor [message #178823 is a reply to message #178747] Tue, 21 September 2004 16:04 Go to previous messageGo to next message
The term is actually CodeAssist. Any ideas why I can only access CodeAssist
via CTRL-SHIFT-SPACE. It doesn't popup by default anymore after pressing
> Sometime ago I lost the autocompletion feature in the Java Editor. Not
> sure if the term is right, but this feature would pop up a window
> suggesting the most appropriate method when starting typying away its
> name. Now I have to rely on F3 to look at the declaration. I would love to
> restore it. Also strangely some menu labels have lost their value. It is
> now replaced by its tags. For example, under Run I have now
> Pascal
Re: Lost autocompletion mode in editor [message #178898 is a reply to message #178823] Wed, 22 September 2004 04:11 Go to previous messageGo to next message
Check "Enable Auto Activation" on the Java>Editor>Content Assist
preference page.
-tom
>>Pascal
Re: Lost autocompletion mode in editor [message #179099 is a reply to message #178898] Thu, 23 September 2004 11:24 Go to previous messageGo to next message
It is checked. This is why I think I am having a problem. Any idea why it
would not work for me. Also why do I lost some menu items description and
only get the labels starting with %. Could those 2 problems related?
Pascal
> preference page.
> -tom
>> CodeAssist via CTRL-SHIFT-SPACE. It doesn't popup by default anymore
>> after pressing '.'
>>>Pascal
Re: Lost autocompletion mode in editor [message #179102 is a reply to message #179099] Thu, 23 September 2004 12:48 Go to previous messageGo to next message
Have you installed any third party plugins (around the time you started
having the problems)?
We have seen things like this before: See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=65278 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71233
Darins
"Pascal Demilly" <list.eclipse@newgenesys.com> wrote in message
news:ciupjg$hh0$1@eclipse.org...
> Pascal
> > preference page.
> > -tom
> >> after pressing '.'
is
> >>>Pascal
Re: Lost autocompletion mode in editor [message #179389 is a reply to message #179102] Fri, 24 September 2004 12:45 Go to previous message
Darin,
Yes. You are right. I have MyEclipse installed. I will try to uninstall it
right now and see if the problem goes away.
Thanks for the info. I love that community. Always helpful and what a
product? Can't seem to work without it anymore?
Pascal
> Darins
>> Pascal
>> > preference page.
>> > -tom
>> >> after pressing '.'
> is
>> >>>Pascal
Previous Topic:References To Class Files Not Working
Next Topic:"Trace into" in Eclipse
Current Time: Fri Jul 25 22:12:15 EDT 2025
Powered by FUDForum. Page generated in 0.25809 seconds
