Language A accessing B language during code generation [message #1787591] |
Tue, 29 May 2018 14:30  |
Hi guys,
I have two Eclipse xtext languages, project A and project B, each one with a grammar.
Language B is a code generation complement for language A.
Language A starts the code generation and it must call some methods in language B to help the work (I do Eclipse Extension Points to solve this). After, language B starts its code generation, based on elements defined in language A.
All works fine when the two plug-ins are executed in Eclipse IDE.
But it fails when running in continuous integration with Maven because Maven cannot access the extension points and so some files aren't generated as in Eclipse IDE.
Some hint about the right way for how language A can access language B during the code generation?
Some hint about how language A can access language B during the code generation without Eclipse extension points? Or there is another way to achieve this?
Márcio Koch.
FUDForum. Page generated in 0.04857 seconds
