Home » Eclipse Projects » Plugin Development Environment (PDE) » Delete Working Set button never enabled.(Is it just me or does anyone else have the same issue with the Delete Working Set button never getting enabled?)
Delete Working Set button never enabled. [message #1787551] Mon, 28 May 2018 12:49 Go to next message
Is it just me or does anyone else have the same issue with the Remove Working Set button never getting enabled.
Windows 10.0.16299
Version: Oxygen.3a Release (4.7.3a)
Build id: 20180405-1200
  • Attachment: Snap65.pdf
    (Size: 55.51KB, Downloaded 166 times)
Re: Delete Working Set button never enabled. [message #1787552 is a reply to message #1787551] Mon, 28 May 2018 13:02 Go to previous message
While a standard context menu delete does work on a empty Working Set in the Package Explorer (See attached screen capture) to get around the issue, it does not explain why the button is never enabled in the dialog. If someone can confirm I will open a bugzilla ticket.
  • Attachment: Snap66.pdf
    (Size: 102.62KB, Downloaded 236 times)
Previous Topic:Not able to launch eclipse application from application.product
Next Topic:Is this the newsgroup for PDE
Current Time: Mon Jul 21 01:25:03 EDT 2025
Powered by FUDForum. Page generated in 0.47294 seconds
