Error in newly installed Oxygen: Unable to locate secure storage module [message #1787513] |
Sun, 27 May 2018 23:20  |
Six months ago I downloaded the latest Eclipse IDE for Java (Oxygen 4.7.1) and when I started I got a repeated error in the logs:
Unable to locate secure storage module (org.eclipse.equinox.security.windowspasswordprovider).
(details below)
I posted it in the bugtracker - zero feedback or news:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=527772
Today I downloaded the latest "Eclipse for RCP and RAP Developers"
(64 bits, Windows) , Oxygen 4.7.3a. Same error. And, worse for me, it also appears in the RCP app.
I'm curious. If find it hard to believe that a freshly installed Eclipse gives systematically such an error. Am I missing something? Am I alone? Does the rest of the users experience this? Any suspect or recipe?
Details: I'm running Java 8, Windows 7 , 64 bits. The error shows in the <workspace_loc>/.metadata/.log file , at start, repeated 6 times:
!ENTRY org.eclipse.core.net 4 0 2018-05-28 00:05:48.269
!MESSAGE Unable to locate secure storage module (org.eclipse.equinox.security.windowspasswordprovider).
!STACK 0
org.eclipse.equinox.security.storage.StorageException: Unable to locate secure storage module (org.eclipse.equinox.security.windowspasswordprovider).
at org.eclipse.equinox.internal.security.storage.PasswordProviderSelector.findStorageModule(PasswordProviderSelector.java:190)
at org.eclipse.equinox.internal.security.storage.SecurePreferencesRoot.getModulePassword(SecurePreferencesRoot.java:233)
at org.eclipse.equinox.internal.security.storage.SecurePreferencesRoot.getPassword(SecurePreferencesRoot.java:226)
at org.eclipse.equinox.internal.security.storage.SecurePreferences.get(SecurePreferences.java:264)
at org.eclipse.equinox.internal.security.storage.SecurePreferencesWrapper.get(SecurePreferencesWrapper.java:106)
at org.eclipse.core.internal.net.ProxyType.loadProxyAuth(ProxyType.java:537)
at org.eclipse.core.internal.net.ProxyType.createProxyData(ProxyType.java:138)
at org.eclipse.core.internal.net.ProxyType.getProxyData(ProxyType.java:127)
at org.eclipse.core.internal.net.PreferenceManager.migrateInstanceScopePreferences(PreferenceManager.java:292)
at org.eclipse.core.internal.net.PreferenceManager.migrate(PreferenceManager.java:260)
at org.eclipse.core.internal.net.ProxyManager.checkMigrated(ProxyManager.java:389)
at org.eclipse.core.internal.net.ProxyManager.initialize(ProxyManager.java:259)
at org.eclipse.core.internal.net.Activator.start(Activator.java:175)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:442)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.jsch.internal.core.JSchCorePlugin.start(JSchCorePlugin.java:243)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:430)
at org.eclipse.egit.core.Activator.setupSSH(Activator.java:215)
at org.eclipse.egit.core.Activator.start(Activator.java:189)
at org.eclipse.egit.ui.Activator$RepositoryChangeScanner.<init>(Activator.java:619)
at org.eclipse.egit.ui.Activator.setupRepoChangeScanner(Activator.java:720)
at org.eclipse.egit.ui.Activator.start(Activator.java:318)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:174)
at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:104)
at org.eclipse.ui.internal.Workbench$34.runWithException(Workbench.java:2367)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:144)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4889)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:95)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:2362)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1641)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2848)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:667)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
FUDForum. Page generated in 0.03323 seconds
