Home » Archived » BIRT » Chart size
Chart size [message #178351] Tue, 18 July 2006 05:11 Go to next message
Originally posted by: emina.karic.dsek.lth.se
When working with charts I've at times run into truble when trying to
determine the best size for charts and extended items. For the few examples
I've done a visual assessment has been adequate, but I'm guessing there's a
better way then trial and error. Any hints on this?
Thanks in advance
Emina
Re: Chart size [message #178513 is a reply to message #178351] Tue, 18 July 2006 13:08 Go to previous messageGo to next message
Emina,
The chart size has to be fixed in advance. Can you explain what exactly is
the problem you're having when setting the size manually?
David
"Emina Karic" <emina.karic@dsek.lth.se> wrote in message
news:e9i8jf$lqa$1@utils.eclipse.org...
> examples
> a
> Thanks in advance
> Emina
Re: Chart size [message #178672 is a reply to message #178513] Wed, 19 July 2006 04:49 Go to previous messageGo to next message
The problem is that the best size depends on runtime data. If I set the
chart size to something that is to big for the runtime data, the axis
scaling gets messed up(barchart.png). Or if it's to small, the chart doesn't
get rendered at all(piechart.png).
Also, the size of the extended item depends on the chartsize. Through trial
and error I've found that the ratio is 4/3. So what I do now is set the
chartsize to fixed ints, and set the extended item to be 4/3 of that. Then
it looks fine, at least if the chart size is large enough to accomodate the
data without being to large (as mentioned above). But, if the runtime data
changes the size has to be changed manually.
Thanks in advance
Emina
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:e9j4if$u9h$1@utils.eclipse.org...
> Emina,
> David
> > examples
there's
> > a
> > Thanks in advance
> > Emina
  • Attachment: piechart.png
    (Size: 2.36KB, Downloaded 114 times)
  • Attachment: barchart.png
    (Size: 1.09KB, Downloaded 90 times)
Re: Chart size [message #178721 is a reply to message #178672] Wed, 19 July 2006 07:30 Go to previous messageGo to next message
Hi Emina,
The Axis scaling doesn't really get messed up, it's because you set the
formatting to integer values on the Y Axis (or put the number of digits to
zero).
I don't really understand what you meam about the extended item depending on
the chart size? Do you create a report with the DE API, or with the BIRT
Designer?
David
news:e9krmh$rkk$1@utils.eclipse.org...
> doesn't
> trial
> the
> Thanks in advance
> Emina
>> Emina,
>> is
>> Thanks,
>> David
>> > examples
> there's
>> > a
>> > Thanks in advance
>> > Emina
Re: Chart size [message #178736 is a reply to message #178721] Wed, 19 July 2006 07:58 Go to previous messageGo to next message
Maybe I should have been more specific. I'm using the API to create reports
containing charts. And yes the Axis scaling gets messed up. If I always set
the chart size to the same thing and the query returns a large enoug number
it will look like barchart2.png. If then the query changes so that less
values are returned it looks like barchart.png. Please note that the only
change in code is the query.
Thanks in advance
Emina
news:e9l555$h38$1@utils.eclipse.org...
> Hi Emina,
> zero).
on
> Designer?
> David
> > doesn't
> > trial
Then
> > the
data
> > Thanks in advance
> > Emina
> >> Emina,
> >> is
> >> Thanks,
> >> David
> >> > examples
> > there's
> >> > a
> >> > Thanks in advance
> >> > Emina
    (Size: 1.09KB, Downloaded 97 times)
  • Attachment: barchart2.png
    (Size: 1.28KB, Downloaded 106 times)
Re: Chart size [message #178745 is a reply to message #178736] Wed, 19 July 2006 08:02 Go to previous messageGo to next message
What I meant is that you should modify the Y Axis labels format to display
some digits, otherwise, they will be rounded to integers like in your
screenshot. Alternatively, you can modify the number of major ticks to show
less of them if you don't have too much datapoints.
David
news:e9l6pd$sa4$1@utils.eclipse.org...
> reports
> set
> number
> Thanks in advance
> Emina
>> Hi Emina,
>> to
>> zero).
> on
>> Designer?
>> Thanks,
>> David
>> > doesn't
>> > trial
> Then
>> > the
> data
>> > Thanks in advance
>> > Emina
>> >> Emina,
>> >> exactly
>> >> is
>> >> Thanks,
>> >> David
>> >> > to
>> >> > examples
>> > there's
>> >> > a
>> >> > Thanks in advance
>> >> > Emina
Re: Chart size [message #178776 is a reply to message #178745] Wed, 19 July 2006 08:48 Go to previous messageGo to next message
Worked like a charm. Thanks a bunch.
I have a similar kind of problem with pie charts. If I have more groups than
expected the charts don't fit and they don't get rendered correctly. Is
there a way to get around this?
Thanks in advance
Emina
news:e9l716$trp$1@utils.eclipse.org...
show
> David
> > reports
> > set
> > number
only
> > Thanks in advance
> > Emina
> >> Hi Emina,
> >> to
> >> zero).
depending
> > on
BIRT
> >> Designer?
> >> Thanks,
> >> David
the
> >> > doesn't
> >> > trial
the
> > Then
accomodate
> >> > the
> > data
> >> > Thanks in advance
> >> > Emina
> >> >> Emina,
> >> >> exactly
> >> >> is
> >> >> Thanks,
> >> >> David
> >> >> > to
> >> >> > examples
> >> > there's
> >> >> > a
> >> >> > Thanks in advance
> >> >> > Emina
Re: Chart size [message #178825 is a reply to message #178745] Wed, 19 July 2006 09:53 Go to previous messageGo to next message
By the way, can the number of major ticks be set in an adaptive manner. The
zoom function usually does a good job of calculating min/max/step. I just
wan't to change the step if it is zoomed in enough to display steps less
than 1. Can it be done?
Thanks in advance
Emina
show
> David
> > reports
> > set
> > number
only
> > Thanks in advance
> > Emina
> >> Hi Emina,
> >> to
> >> zero).
depending
> > on
BIRT
> >> Designer?
> >> Thanks,
> >> David
the
> >> > doesn't
> >> > trial
the
> > Then
accomodate
> >> > the
> > data
> >> > Thanks in advance
> >> > Emina
> >> >> Emina,
> >> >> exactly
> >> >> is
> >> >> Thanks,
> >> >> David
> >> >> > to
> >> >> > examples
> >> > there's
> >> >> > a
> >> >> > Thanks in advance
> >> >> > Emina
Re: Chart size [message #179098 is a reply to message #178776] Thu, 20 July 2006 10:51 Go to previous messageGo to next message
You mean if you have multiple Pie charts, but you don't know how many in
advance?
Note that you can set the number of columns to layout multiple charts, I
think this can be done dynamically in beforeGeneration too. Otherwise a good
idea would be to show the data labels inside the pies (they take less space
this way), or simply as tooltips.
David
news:e9l9no$fg3$1@utils.eclipse.org...
> than
> Thanks in advance
> Emina
>> display
> show
>> Thanks,
>> David
>> > reports
>> > set
>> > number
> only
>> > Thanks in advance
>> > Emina
>> >> Hi Emina,
>> >> the
>> >> digits
>> >> to
>> >> zero).
> depending
>> > on
> BIRT
>> >> Designer?
>> >> Thanks,
>> >> David
> the
>> >> > axis
>> >> > doesn't
>> >> > Through
>> >> > trial
> the
>> >> > that.
>> > Then
> accomodate
>> >> > the
>> >> > runtime
>> > data
>> >> > Thanks in advance
>> >> > Emina
>> >> >> Emina,
>> >> >> exactly
>> >> >> is
>> >> >> Thanks,
>> >> >> David
>> >> >> > trying
>> >> >> > to
>> >> >> > few
>> >> >> > examples
>> >> >> > guessing
>> >> > there's
>> >> >> > a
>> >> >> > Thanks in advance
>> >> >> > Emina
Re: Chart size [message #179101 is a reply to message #178825] Thu, 20 July 2006 10:52 Go to previous messageGo to next message
How do you zoom exactly? You regenerate the chart? Then at that time you can
specify the number of ticks in the chart model before regeneration. If
you're talking about zooming inside SVG, no ticks can be added at that time,
since it's a "static " zoom.
David
news:e9ldgc$8f5$1@utils.eclipse.org...
> The
> Thanks in advance
> Emina
>> display
> show
>> Thanks,
>> David
>> > reports
>> > set
>> > number
> only
>> > Thanks in advance
>> > Emina
>> >> Hi Emina,
>> >> the
>> >> digits
>> >> to
>> >> zero).
> depending
>> > on
> BIRT
>> >> Designer?
>> >> Thanks,
>> >> David
> the
>> >> > axis
>> >> > doesn't
>> >> > Through
>> >> > trial
> the
>> >> > that.
>> > Then
> accomodate
>> >> > the
>> >> > runtime
>> > data
>> >> > Thanks in advance
>> >> > Emina
>> >> >> Emina,
>> >> >> exactly
>> >> >> is
>> >> >> Thanks,
>> >> >> David
>> >> >> > trying
>> >> >> > to
>> >> >> > few
>> >> >> > examples
>> >> >> > guessing
>> >> > there's
>> >> >> > a
>> >> >> > Thanks in advance
>> >> >> > Emina
Re: Chart size [message #180105 is a reply to message #179101] Wed, 26 July 2006 05:20 Go to previous messageGo to next message
It seems that formatting the axis labels is the best choice here. Thanks a
lot for your help.
Emina
news:e9o5bf$atg$1@utils.eclipse.org...
can
time,
> David
> > The
just
> > Thanks in advance
> > Emina
> >> display
> > show
> >> Thanks,
> >> David
> >> > reports
always
> >> > set
> >> > number
less
> > only
> >> > Thanks in advance
> >> > Emina
> >> >> Hi Emina,
> >> >> the
> >> >> digits
> >> >> to
> >> >> zero).
> > depending
> >> > on
> > BIRT
> >> >> Designer?
> >> >> Thanks,
> >> >> David
set
> > the
> >> >> > axis
chart
> >> >> > doesn't
> >> >> > Through
> >> >> > trial
set
> > the
> >> >> > that.
> >> > Then
> > accomodate
> >> >> > the
> >> >> > runtime
> >> > data
> >> >> > Thanks in advance
> >> >> > Emina
> >> >> >> Emina,
> >> >> >> exactly
> >> >> >> is
> >> >> >> Thanks,
> >> >> >> David
> >> >> >> > trying
> >> >> >> > to
> >> >> >> > few
> >> >> >> > examples
> >> >> >> > guessing
> >> >> > there's
> >> >> >> > a
> >> >> >> > Thanks in advance
> >> >> >> > Emina
Re: Chart size [message #180113 is a reply to message #179098] Wed, 26 July 2006 05:21 Go to previous message
Thanks for the pointer. I'll probably go with the columns. From the little
experimenting I've done it does the best job. Thanks a lot.
Emina
news:e9o58o$9u3$1@utils.eclipse.org...
> advance?
good
space
> David
> > than
> > Thanks in advance
> > Emina
> >> display
> > show
> >> Thanks,
> >> David
> >> > reports
always
> >> > set
> >> > number
less
> > only
> >> > Thanks in advance
> >> > Emina
> >> >> Hi Emina,
> >> >> the
> >> >> digits
> >> >> to
> >> >> zero).
> > depending
> >> > on
> > BIRT
> >> >> Designer?
> >> >> Thanks,
> >> >> David
set
> > the
> >> >> > axis
chart
> >> >> > doesn't
> >> >> > Through
> >> >> > trial
set
> > the
> >> >> > that.
> >> > Then
> > accomodate
> >> >> > the
> >> >> > runtime
> >> > data
> >> >> > Thanks in advance
> >> >> > Emina
> >> >> >> Emina,
> >> >> >> exactly
> >> >> >> is
> >> >> >> Thanks,
> >> >> >> David
> >> >> >> > trying
> >> >> >> > to
> >> >> >> > few
> >> >> >> > examples
> >> >> >> > guessing
> >> >> > there's
> >> >> >> > a
> >> >> >> > Thanks in advance
> >> >> >> > Emina
Previous Topic:Relatief File path
Next Topic:Support XMLA and ODBO datasources
Current Time: Sat Oct 25 13:56:03 EDT 2025
Powered by FUDForum. Page generated in 0.06519 seconds
