Home » Eclipse Projects » OM2M » JSON content "con" attribute in ContentInstance
JSON content "con" attribute in ContentInstance [message #1787232] Tue, 22 May 2018 09:44 Go to next message
I created an AE named SAMPLE_AE, with a DATA container in it. Then I want to send a JSON contentInstance under the DATA container. So I post an HTTP Request with the following content:
   "m2m:cin": {
     "cnf": "application/json",
     "con": {
     	"appId": "SAMPLE_AE",
     	"category": "sample_category",
     	"value": "1"
But here is the response I get :
Status : 201 created
    "m2m:cin": {
        "rn": "cin_490476127",
        "ty": 4,
        "ri": "/mn-cse/cin-490476127",
        "pi": "/mn-cse/cnt-644912348",
        "ct": "20180522T133731",
        "lt": "20180522T133731",
        "st": 0,
        "cs": 0,
        "con": ""
The JSON content is ignored. It works only if I set a single string (e.g "con":"1"). I found a workaround using oBIX :
   "m2m:cin": {
     "cnf": "application/obix:0",
     "con": "<obj>
     <str name=\"appId\" val=\"SAMPLE_AE\"/>
     <str name=\"category\" val=\"sample_category\"/>
     <int name=\"value\" val=\"1\"/>
     </obj>"
This works but is less easy to integrate in my solution.
Am I doing anything wrong?
Re: JSON content "con" attribute in ContentInstance [message #1787271 is a reply to message #1787232] Wed, 23 May 2018 00:01 Go to previous messageGo to next message
can u give a try with this one?
   "m2m:cin": {
     "con": {
     	\"appId\": \"SAMPLE_AE\",
     	\"category\": \"sample_category\",
     	\"value\": \"1\"
[Updated on: Wed, 23 May 2018 00:10] by Moderator
Re: JSON content "con" attribute in ContentInstance [message #1787292 is a reply to message #1787271] Wed, 23 May 2018 04:58 Go to previous messageGo to next message
Thanks for your answer. I just tried that and I get a 400 - Bad Request : Error in provided content error.
Here is the log from the MN-CSE in this case :
[INFO] - org.eclipse.om2m.binding.http.RestHttpServlet
Content type headers: application/json;ty=4
Header value: application/json
Header value: ty=4
Accept header: application/json
[INFO] - org.eclipse.om2m.core.router.Router
Received request in Router: RequestPrimitive [operation=1,
 to=/mn-cse/mn-name/SAMPLE_AE/DATA,
 from=admin:admin,
 resourceType=4,
 content= {
   "m2m:cin": {
     "con": {
        \"value\": \"1\"
 filterCriteria=org.eclipse.om2m.commons.resource.FilterCriteria@f4d5de,
 returnContentType=application/json,
 requestContentType=application/json,
 queryStrings={}]
Request handling in the current CSE: /mn-cse/mn-name/SAMPLE_AE/DATA
ResourceController to be used [ContentInstanceController]
line 5:6 no viable alternative at character '\'
line 11:0 mismatched character '<EOF>' expecting '"'
line 0:-1 mismatched input '<EOF>' expecting '}'
[ERROR] - org.eclipse.om2m.datamapping.jaxb.Mapper
JAXB unmarshalling error!
javax.xml.bind.UnmarshalException
 - with linked exception:
[Exception [EclipseLink-25004] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.XMLMarshalException
Exception Description: An error occurred unmarshalling the document
Re: JSON content "con" attribute in ContentInstance [message #1814444 is a reply to message #1787292] Wed, 11 September 2019 09:52 Go to previous messageGo to next message
I have the same issue.
Instead of oBIX, I'd like POST nested JSON contents in "con" field to handle easily with Javascript program for AE.
Any solution?
Currently I'm posting data with Postman for testing purpose.
The following is header and body of HTTP POST message to CSE.
<Request>
POST /~/in-cse/in-name/sensor_ae/environment HTTP/1.1
X-M2M-Origin: CAE941252566
X-M2M-RI: 20000004
Content-Type: application/json;ty=4
Accept: application/json
User-Agent: PostmanRuntime/7.16.3
Cache-Control: no-cache
Postman-Token: f798ef06-bda0-47a6-9674-4248a68202e9
Host: 192.168.0.242:8080
Accept-Encoding: gzip, deflate
Content-Length: 190
Connection: keep-alive
"m2m:cin": {
"con": {
"value": "1"
<Response>
HTTP/1.1 201 Created
Content-Location: /in-cse/cin-509864000
X-M2M-RI: 20000004
X-M2M-Origin: /in-cse
X-M2M-RSC: 2001
Content-Type: application/json;charset=UTF-8
Content-Length: 294
Server: Jetty(8.1.16.v20140903)
"m2m:cin" : {
"rn" : "cin_509864000",
"ty" : 4,
"ri" : "/in-cse/cin-509864000",
"pi" : "/in-cse/cnt-840362991",
"ct" : "20190911T224323",
"lt" : "20190911T224323",
"st" : 0,
"cnf" : "application/json",
"cs" : 0,
"con" : ""
Looking at in-cse log, "con" : <Object> was received by RestHttp, but ignored at RestHttpClient.
Built RequestPrimitive: RequestPrimitive [to=/in-cse/in-name/sensor_ae/environment,
 content={
    "m2m:cin": {
        "con": {
            "value": "1"
 filterCriteria=org.eclipse.om2m.commons.resource.FilterCriteria@ef4e5e6,
Header value: ty=4
 from=CAE941252566,
 requestIdentifier=20000004,
 resourceType=4,
 content={
    "m2m:cin": {
        "con": {
            "value": "1"
 queryStrings={}]
Request handling in the current CSE: /in-cse/in-name/sensor_ae/environment
[INFO] - org.eclipse.om2m.core.controller.Controller
Deleting oldest content instance due to container size limit
[INFO] - org.eclipse.om2m.core.notifier.Notifier
Sending notify request to: /in-cse/CAE414512124
Sending notify request...
Received request in Router: RequestPrimitive [operation=5,
 to=/in-cse/CAE414512124,
 from=admin:admin,
 content={
   "m2m:sgn" : {
      "m2m:nev" : {
         "m2m:rep" : {
            "m2m:cin" : {
               "ty" : 4,
               "st" : 0,
               "cs" : 0,
               "con" : ""
         "m2m:rss" : 1
      "m2m:sud" : false,
      "m2m:sur" : "/in-cse/sub-947316430"
No Accept parameter set, setting to default: application/xml
Request handling in the current CSE: /in-cse/CAE414512124
[INFO] - org.eclipse.om2m.core.comm.RestClient
the requestIndication RC: RequestPrimitive [operation=5,
 to=http://192.168.0.242:8000/Environment,
 from=admin:admin,
 content={
   "m2m:sgn" : {
      "m2m:nev" : {
         "m2m:rep" : {
            "m2m:cin" : {
               "ty" : 4,
               "st" : 0,
               "cs" : 0,
               "con" : ""
         "m2m:rss" : 1
      "m2m:sud" : false,
 returnContentType=application/xml,
[INFO] - org.eclipse.om2m.binding.http.RestHttpClient
Sending request: RequestPrimitive [operation=5,
 from=admin:admin,
 content={
   "m2m:sgn" : {
      "m2m:nev" : {
         "m2m:rep" : {
            "m2m:cin" : {
               "ty" : 4,
               "st" : 0,
               "cs" : 0,
               "con" : ""
         "m2m:rss" : 1
      "m2m:sud" : false,
Clear and close transaction
Response in Router= ResponsePrimitive [
 responseStatusCode=2001
 to=CAE941252566
 from=/in-cse
 location=/in-cse/cin-509864000,
 contentType=application/json,
 content (Only first 1000 caracters)=
   "m2m:cin" : {
      "ty" : 4,
      "st" : 0,
      "cs" : 0,
      "con" : ""
Re: JSON content "con" attribute in ContentInstance [message #1815566 is a reply to message #1814444] Sat, 05 October 2019 04:07 Go to previous messageGo to next message
Looking at previous discussion, I understood that it is necessary to parentheses JSON objet by "" like:
    "m2m:cin": {
        "cnf": "application/text",
        "con": "{\"Location\": \"Outside\", \"RSSI\": -53, \"TemperatureC\": 30.34, \"Humidity\": 47.42, \"PressureHpa\": 1001.36, \"CreateDate\": \"2019-10-05T07:59:58Z\"}"
OM2M accepted this container instance as a string.
[2019-10-05 16:59:54,732 INFO] - org.eclipse.om2m.binding.http.RestHttpClient
 from=admin:admin,
 content={
   "m2m:sgn" : {
      "m2m:nev" : {
         "m2m:rep" : {
            "m2m:cin" : {
               "rn" : "cin_727923535",
               "ty" : 4,
               "ri" : "/in-cse/cin-727923535",
               "pi" : "/in-cse/cnt-813712573",
               "ct" : "20191005T165954",
               "lt" : "20191005T165954",
               "st" : 0,
               "cnf" : "application/text",
               "cs" : 140,
               "con" : "{\"Location\": \"Outside\", \"RSSI\": -53, \"TemperatureC\": 30.34, \"Humidity\": 47.42, \"PressureHpa\": 1001.36, \"CreateDate\": \"2019-10-05T07:59:58Z\"}"
         "m2m:rss" : 1
      "m2m:sud" : false,
      "m2m:sur" : "/in-cse/sub-242671093"
[Updated on: Sat, 05 October 2019 04:35] by Moderator
Re: JSON content "con" attribute in ContentInstance [message #1816494 is a reply to message #1815566] Wed, 30 October 2019 03:30 Go to previous message
Due to OM2M using JAXB tool to parse the received oneM2M bodies, the "con" attribute should be escaped if containing any nested JSON object. It is not parsed properly otherwise.
This does not change the behavior of the platform but just facilitates the parsing and storing of the content.
[Updated on: Mon, 04 November 2019 04:05] by Moderator
Previous Topic:problem to build om2m
Next Topic:print messages on console
Current Time: Sat Jul 26 11:32:43 EDT 2025
Powered by FUDForum. Page generated in 0.44109 seconds
