Home » Language IDEs » Java Development Tools (JDT) » Simple compilation fails in Eclipse Oxygen.3a( )
Simple compilation fails in Eclipse Oxygen.3a [message #1786959] Wed, 16 May 2018 08:14 Go to next message
I wish to migrate a Java application (Java 8) from Eclipse 4.4 to Eclipse 4.7 but I encounter a strange problem. I present you below, my use scenario:
Using Eclipse UI (rught clikc -> New -> Class), I create a new class (DevWebMetadata2) that extends an existed class (DevWebMetadataAdapter). After this, I use the Eclipse UI (right click -> Source -> Override methods...) to override only one method.
So, I didn't touch the class generated/created by Eclipse but I obtain a compilation error for the new created class.
import java.util.List;
public class DevWebMetadata2 extends DevWebMetadataAdapter
	public List<Class<? extends IIdentifiable>> getMetaDataIdWeb()
		// TODO Auto-generated method stub
		return super.getMetaDataIdWeb();
The error messages is
Type mismatch: cannot convert from List<Class<? extends IIdentifiable>> to List<Class<? extends IIdentifiable>>
Version: Oxygen.3a Release (4.7.3a)
Build id: 20180405-1200
org.eclipse.jdt.core version: 3.13.102.v20180330-0919
Is it a bug in compiler?
If you need more information, please ask.
[Updated on: Thu, 17 May 2018 02:34] by Moderator
Re: Simple compilation failes in Eclipse Oxygen [message #1786979 is a reply to message #1786959] Wed, 16 May 2018 14:39 Go to previous messageGo to next message
If IIdentifiable is a raw type, then this is https://bugs.eclipse.org/bugs/show_bug.cgi?id=532137
This is fixed in 4.8M7 (download SDK now from http://download.eclipse.org/eclipse/downloads/ or other packages in a few days from https://www.eclipse.org/downloads/index-developer.php)
Re: Simple compilation failes in Eclipse Oxygen [message #1786999 is a reply to message #1786979] Thu, 17 May 2018 02:01 Go to previous messageGo to next message
IIdentifiable looks like
public interface IIdentifiable<T extends IIdentifiable<T>>
    Id<T> getId();
    // other methods
Re: Simple compilation failes in Eclipse Oxygen [message #1787032 is a reply to message #1786979] Thu, 17 May 2018 08:58 Go to previous message
Thanks!
I can confirm that on Eclipse SDK 4.8M7 (Version: Photon (4.8), Build id: I20180509-2000) everything works OK.
So, it's very possible to be Bug 532137 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=532137).
Previous Topic:Reading value programmertically from IJavaVariable instance
Next Topic:Compilation problem with exceptions
Current Time: Sun Jul 27 16:17:04 EDT 2025
Powered by FUDForum. Page generated in 0.04247 seconds
