Home » Eclipse Projects » Sirius » Warning: The EClass XXX used in domainClass is not accessible
Warning: The EClass XXX used in domainClass is not accessible [message #1786930] Tue, 15 May 2018 22:03 Go to next message
Hi.
What does this warning message mean?
"The EClass XXX used in domainClass is not accessible. You are most likely trying to use an EClass without having a dependency to its plugin."
How can I solve it?
Regards.
Re: Warning: The EClass XXX used in domainClass is not accessible [message #1786946 is a reply to message #1786930] Wed, 16 May 2018 04:00 Go to previous messageGo to next message
As mentioned in the error message, the plugin containing your modeler definition must have a dependency towards the plug-in which defines your metamodel.
Re: Warning: The EClass XXX used in domainClass is not accessible [message #1786962 is a reply to message #1786946] Wed, 16 May 2018 08:56 Go to previous messageGo to next message
Pierre,
the strange thing is that my project was working fine. I was trying to integrate it with an Acceleo project. Suddenly, this message appears.
Where I must look to fix this error?
Re: Warning: The EClass XXX used in domainClass is not accessible [message #1786964 is a reply to message #1786962] Wed, 16 May 2018 10:26 Go to previous message
When you edit a Sirius diagram or an Acceleo transformation you are running within Eclipse and everything registered in your Eclipse workspace can be accessible.
When you run an Acceleo transformation you are running a standalone Java application with some help from Eclipse in that the classpath is auto-generated from the MANIFEST.MF; it uses only what is registered in the MANIFEST.MF. Therefore fix your classpath, by adding a MANIFEST.MF dependency to what you need. That should fix it for simple file layouts. If you have a complex workspace spread across many GIT locations, you could be in trouble.
Ed Willink
Previous Topic:Some Validation Rules are not executed properly within the generated plugin.
Next Topic:The feature 'activatedLayers' has a reference to '' which cannot be f
Current Time: Mon Jul 21 02:37:23 EDT 2025
Powered by FUDForum. Page generated in 0.09264 seconds
