Home » Modeling » TMF (Xtext) » Xtend Active annotations: Statically import method
Xtend Active annotations: Statically import method [message #1786934] Wed, 16 May 2018 02:24 Go to next message
I would like to use a statically imported method in code generated with Xtend's active annotations. As an example, I want to get this output:
import static java.util.Collections.emptyList;
@MyActiveAnnotation
public class MyTest {
    public void foo() {
        emptyList();
My compilation participant looks like this:
override doTransform(MutableClassDeclaration clazz, extension TransformationContext context) {
clazz.addMethod("foo", [
    body = '''
        «Collections».emptyList();
While this code works and imports Collections, it doesn't statically import the emptyList method.
How can I statically import methods using Xtend's active annotations?
Re: Xtend Active annotations: Statically import method [message #1786937 is a reply to message #1786934] Wed, 16 May 2018 02:38 Go to previous messageGo to next message
what do you exactly want to achieve?
why do you need the static import?
afaik there is no possibiity to add imports like that
Re: Xtend Active annotations: Statically import method [message #1786938 is a reply to message #1786937] Wed, 16 May 2018 02:41 Go to previous messageGo to next message
I simply want to improve readability of the generated code.
Re: Xtend Active annotations: Statically import method [message #1786945 is a reply to message #1786938] Wed, 16 May 2018 03:59 Go to previous messageGo to next message
as i said i dont know a possibility
Re: Xtend Active annotations: Statically import method [message #1786947 is a reply to message #1786938] Wed, 16 May 2018 04:01 Go to previous messageGo to next message
As these import lines are on top of the output file:
Wouldn't it be an option to create these lines BEFORE traversing the tree ?
If you need to look for the existence of rules etc.
the generator from GREETINGS provides an example.
Re: Xtend Active annotations: Statically import method [message #1786955 is a reply to message #1786947] Wed, 16 May 2018 07:16 Go to previous messageGo to next message
Where can I find this GREETINGS example?
Re: Xtend Active annotations: Statically import method [message #1786963 is a reply to message #1786955] Wed, 16 May 2018 09:20 Go to previous messageGo to next message
this wont help
active annotations and normal generators have nothing in common
Re: Xtend Active annotations: Statically import method [message #1786967 is a reply to message #1786963] Wed, 16 May 2018 10:48 Go to previous message
Ok. Thanks, Christian.
Previous Topic:Xtext with other AST generators
Next Topic:Error "Type Duplicate JvmIdentifiableElement '<unnamed>'"
Current Time: Mon Jun 16 13:07:51 EDT 2025
Powered by FUDForum. Page generated in 0.04464 seconds
