Home » Eclipse Projects » Oomph » Installation error. Can't download findbugs plugin.
Installation error. Can't download findbugs plugin. [message #1786578] Mon, 07 May 2018 13:27 Go to next message
Hi.
I try to install Eclipse (Oomph) with OpenDayLight Project and each time the installation stops with same error.
org.eclipse.equinox.p2.transport.ecf code=1200 Artifact not found: hxxp://findbugs.cs.umd.edu/eclipse-daily/plugins/edu.umd.cs.findbugs.plugin.eclipse_3.0.2.20170921-25417ff.jar
I try with different version of Eclipse/Java and still nothing.
Full error logs:
ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while collecting items to be installed
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:547)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:733)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3332)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3260)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3241)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3141)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:575)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:701)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=_home_filip_controller-master3_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
ERROR: org.eclipse.equinox.p2.transport.ecf code=1200 Artifact not found: hxxp://findbugs.cs.umd.edu/eclipse-daily/plugins/edu.umd.cs.findbugs.plugin.eclipse_3.0.2.20170921-25417ff.jar.
java.io.FileNotFoundException: hxxp://findbugs.cs.umd.edu/eclipse-daily/plugins/edu.umd.cs.findbugs.plugin.eclipse_3.0.2.20170921-25417ff.jar
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryStatusHelper.checkFileNotFound(RepositoryStatusHelper.java:297)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.checkException(FileReader.java:476)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:433)
at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.readInto(FileReader.java:360)
at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:101)
at org.eclipse.oomph.p2.internal.core.CachingTransport.download(CachingTransport.java:135)
at org.eclipse.oomph.p2.internal.core.CachingTransport.download(CachingTransport.java:255)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:678)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:600)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:732)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.getArtifact(MirrorRequest.java:319)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transferSingle(MirrorRequest.java:288)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.transfer(MirrorRequest.java:223)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRequest.perform(MirrorRequest.java:153)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:716)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:787)
at org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch(DownloadManager.java:113)
at org.eclipse.equinox.internal.p2.engine.DownloadManager.start(DownloadManager.java:101)
at org.eclipse.equinox.internal.p2.engine.phases.Collect.completePhase(Collect.java:108)
at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:252)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:102)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:47)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:77)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:45)
at org.eclipse.equinox.internal.provisional.p2.director.PlanExecutionHelper.executePlan(PlanExecutionHelper.java:42)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:543)
Any suggestions how to get around this issue? Or solve it?
Re: Installation error. Can't download findbugs plugin. [message #1786652 is a reply to message #1786578] Wed, 09 May 2018 00:02 Go to previous messageGo to next message
I just tried and have the same result. It seems that their Findbugs daily update site is corrupt / missing jars. It does work with http://findbugs.cs.umd.edu/eclipse-candidate , but that update site serves up the 2 years older version 3.0.1.20150306-5afe4d1 . Someone should inform them about the problem with their update site.
In the meantime you can temporarily redirect your project setup by pasting the following snippet into your user.setup (Nvigate -> Open Setup -> User):
<setup:RedirectionTask
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    sourceURL="http://findbugs.cs.umd.edu/eclipse-daily"
    targetURL="http://findbugs.cs.umd.edu/eclipse-candidate"/>
Re: Installation error. Can't download findbugs plugin. [message #1786700 is a reply to message #1786652] Wed, 09 May 2018 11:25 Go to previous messageGo to next message
Thank you for your response.
But I can not paste this snippet directly in my user.setup, Eclipse importer still try to connect with unavailable site. I also try to put RedirectionTask in that way:
 <setupTask
      xsi:type="setup:RedirectionTask"
But it doesn't help.
Attach my entire user.setup file.
Could you tell me how to paste it correctly?
  • Attachment: user.setup
    (Size: 2.93KB, Downloaded 232 times)
Re: Installation error. Can't download findbugs plugin. [message #1786732 is a reply to message #1786700] Thu, 10 May 2018 03:25 Go to previous messageGo to next message
It's described in https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Copying_Tasks_and_Other_Elements ;-)
Re: Installation error. Can't download findbugs plugin. [message #1787074 is a reply to message #1786732] Fri, 18 May 2018 08:45 Go to previous message
Hi Eike,
I encountered the same error with Eclipse Installer.
I already tried to paste your xml snippet just like what Filip did but the error still appear. I found the user.setup on ~/.eclipse/org.eclipse.oomph.setup/setups/user.setup
I think the steps from wiki couldn't be implemented in Eclipse Installer because there is no Navigate->Open Setup->Parent Models->Open Catalog Index on Eclipse Installer.
I will attached my default user.setup file below
Any help would be appreciated.
    (Size: 3.30KB, Downloaded 275 times)
Previous Topic:Empty variables wizard page
Next Topic:Can't install eclipse with installer -
Current Time: Fri Jul 25 08:44:26 EDT 2025
Powered by FUDForum. Page generated in 0.05470 seconds
