Home » Modeling » TMF (Xtext) » Xtext Lexer and Parser(Xtext Lexer and Parser)
Xtext Lexer and Parser [message #1786605] Tue, 08 May 2018 05:54
I am working to build an editor for one of the legacy language.
I got stuck at place where I need some help.
I am trying to explain my problem with java example.
Class Test {
           public static void main(String[] args ){
                 System.out.println("Virag");
                 method();
           public static method(){
                System.out.println("Purnam");
Now in the above example, I want to parse the main class and if any methods are called then that method content should be part of my main class code.
Expected content in document.
Class Test {
I can achieve this in lexer, but after that I face problem is editor.
After parsing I get the proper content, but in next iteration it is creating problem.
As character positions got changed, on edit it enters/delete characters from wrong text region.
How to fix this in editor, so that edit works fine.
How can I fix this? Any help will be much appreciated.
Thanks and regards,
Virag Purnam
Previous Topic:DSL template functions (specialization)
Next Topic:How to let Tycho resolve dependencies in xtext-maven-plugin?
Current Time: Sun Jul 20 21:21:37 EDT 2025
Powered by FUDForum. Page generated in 0.18314 seconds
