Home » Eclipse Projects » BPMN 2.0 Modeler » Trigger the update of an other instance of my extension
Trigger the update of an other instance of my extension [message #1786461] Thu, 03 May 2018 13:03 Go to next message
This is what I need : When I change a property value in my extension, an update is done end the appearance of my feature is changed. I would like that at the same time, this value is sent the value to an other instance of my extension and trigger the update of to this instance.
How can I do that ?
Re: Trigger the update of an other instance of my extension [message #1786596 is a reply to message #1786461] Tue, 08 May 2018 03:31 Go to previous messageGo to next message
take a look here:
https://wiki.eclipse.org/BPMN2-Modeler/DeveloperTutorials/Adapters
https://wiki.eclipse.org/BPMN2-Modeler/DeveloperTutorials/Validation
Reacting on a Notification event may be a solution.
I hope this helps you to solve your problem
Ralph
Re: Trigger the update of an other instance of my extension [message #1786743 is a reply to message #1786596] Thu, 10 May 2018 10:23 Go to previous message
Hi Ralph,
I'm trying to reproduce the example of the CustomLayoutAdapter from the wiki , but it doesn't work. Here is the code :
@Override public IAddFeature getAddFeature(IFeatureProvider fp) {
	return new AddIntermediateCatchEventFeature(fp) {
But getAddFeature(IFeatureProvider fp) has to return an IAddFeature , and AddIntermediateCatchEventFeature(fp) doesn't match.
I tried too to reproduce the example org.eclipse.bpmn2.modeler.examples.dynamic, but the method resourceSetChanged(ResourceSetChangeEvent event) is never triggered...
Can you help me please ?
Previous Topic:BPMN Plugin extraction
Next Topic:problem with displaying large diagram
Current Time: Sun Aug 31 18:42:28 EDT 2025
Powered by FUDForum. Page generated in 0.03470 seconds
