Home » Eclipse Projects » Kura » Kura Debugger Access Issue(Kura Debugger Access Issue)
Kura Debugger Access Issue [message #1786554] Mon, 07 May 2018 04:16 Go to next message
hello,
i'm currently using a Kura 3.0 version for the development of a Java firmware in a Linux Distro ( Yocto Poky).
i'm having difficulties to run the Kura Debugger.
i've followed the guideline at the path of kura dev remote-debugging.html
but i'm not able to access to the debugger because the kura_debug.sh gives me access denied.
i've already troubleshooted the netstat and the port 8000 is enabled.
on web ui i'm not able to see any Firewall configuration.
i run the test on localhost.
regarding the page i see that the port 8000 is in listening mode. whenever a eclipse module start to connect i see the access denied and the port 800 is closed ( i'm not seeing any longer in the net port list).
is there any configuration that i'm missing
Re: Kura Debugger Access Issue [message #1786900 is a reply to message #1786554] Tue, 15 May 2018 03:47 Go to previous message
Hi All,
i've an update where i can ask your support.
the debugger itself it seems that i've been able to manage it ( i've recompiled the code with Maven debug) and when i open the Debug perspective i'm able to see the threads.
suspending the threadds the system stops so the debugger seems to be fine.
the only problem is that whenever i put a breakpoint the software will not hit anytime my breakpoint even if it is in a point of code where the hit is assured.
is it required any eclipse configuratio to trigger that?
thanks
Previous Topic:Driver OPC UA and arrays
Next Topic:Cannot Write to OPCUA Asset
Current Time: Thu Jul 31 14:15:23 EDT 2025
Powered by FUDForum. Page generated in 0.46480 seconds
