Home » Modeling » TMF (Xtext) » Define grammar in Xtext for optional array dimensions
Define grammar in Xtext for optional array dimensions [message #1786413] Wed, 02 May 2018 23:27 Go to next message
I'm trying to define grammar in xtext for arrays where dimensions can be empty like int[][] or int[5][10]
My grammar looks like:
ArrayType:
     [BasicType] ('['(dimension+=Expression)?']')+;
The problem with that rule when I use int[][] is there is no way from the model to know how many [] included because dimension list would be empty.
So I wonder if there is a way in xtext to default value like 0 in case Expression wasn't found? Otherwise what is the best way to handle such situation.
Thanks in advance for your help.
Re: Define grammar in Xtext for optional array dimensions [message #1786512 is a reply to message #1786413] Fri, 04 May 2018 16:23 Go to previous messageGo to next message
What about moving these to a subobject
ArrayThingy: component=[Sometype] dimensions += Dimension+;
Dimension: {Dimension}'[' exp=Expression? ']'^
Re: Define grammar in Xtext for optional array dimensions [message #1786530 is a reply to message #1786512] Sat, 05 May 2018 20:41 Go to previous messageGo to next message
Thanks Christian,
I thought about this, but I didn't want to change my metamodel. I hoped to find some other solution, but it seems I will need to go with that one.
Re: Define grammar in Xtext for optional array dimensions [message #1786531 is a reply to message #1786530] Sun, 06 May 2018 02:46 Go to previous messageGo to next message
You can always use node model but that sucks usability wise in that usecase
Re: Define grammar in Xtext for optional array dimensions [message #1786533 is a reply to message #1786531] Sun, 06 May 2018 03:45 Go to previous message
Changing the metamodel can be a pain, but eventually not changing the metamodel can be a greater pain. Since "[]" is significant, you might care to step back a bit and realize that the indequate distinction between "[]" and "" is actually a metamodel bug that Xtext has identified for you.
Ed Willink
Previous Topic:XBASE content assist inconsistent behavior
Next Topic:How to change lexer to copy tokens from other files
Current Time: Thu Nov 06 11:19:57 EST 2025
Powered by FUDForum. Page generated in 0.04200 seconds
