Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Watching an sub application
Watching an sub application [message #1786216] Fri, 27 April 2018 00:53 Go to next message
hello,
i don't know if this is a bug or if i just making something wrong, but it looks like there is no way to watch the ios of an sub application, is this right?
Re: Watching an sub application [message #1786354 is a reply to message #1786216] Tue, 01 May 2018 18:36 Go to previous messageGo to next message
you are not making anything wrong. Currently watching sub-app interface elements is not supported. We have it on our todo list [1] and I hope to get it working for the first maintaince release of 4diac 1.9.
Alois
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=528020
Re: Watching an sub application [message #1786445 is a reply to message #1786354] Thu, 03 May 2018 07:49 Go to previous messageGo to next message
After spending the last days looking deeper into th watch infrastructure I found out that it is not as easy as I had it expected to fix this issue. There will also be some code clean-up be necessary. Therefore I have to move this fix for the 1.10.0 release. But if you want to test early you can set your 4diac update site to the nightly build site [1].
But be warned that this is realy the unstable direct build of our development branch.
http://download.eclipse.org/4diac/nightly/update
Re: Watching an sub application [message #1786566 is a reply to message #1786445] Mon, 07 May 2018 07:52 Go to previous messageGo to next message
thanks for your answer.
For now my sub-apps aren't really complexe, so i think i can wait until there is a stable version, but thanks for spending your time on this problem.
Re: Watching an sub application [message #1786670 is a reply to message #1786566] Wed, 09 May 2018 03:53 Go to previous message
You are welcome. The main work for 1.9.0 was to lay the basis for finally having a IEC 61499 tool that fully supports subapplications in a usefull way. Any feedback on issues and how to improve subapplication support are very welcome.
Previous Topic:Problem with 4DIAC 1.9.0 versions on Mac OS X
Next Topic:Help with ads1115 and 4diac
Current Time: Sun Jul 27 03:41:58 EDT 2025
Powered by FUDForum. Page generated in 0.04419 seconds
