Home » Eclipse Projects » Model Driven Health Tools » how to install MDHT in eclipse
how to install MDHT in eclipse [message #1781243] Sun, 04 February 2018 13:54 Go to next message
i tried to install MDHT on eclipse but i fieled , can every one please give me a correct methode to install it ?
Re: how to install MDHT in eclipse [message #1781457 is a reply to message #1781243] Wed, 07 February 2018 07:49 Go to previous messageGo to next message
We currently are using eclipse install
This is the link for using MDHT in analysis mode
https://github.com/mdht/mdht-models/blob/volume3/releng/setups/OxygenMDHT.setup
This mode allows you to validate cda and develop java applications
There is a modeling environment which allows you to create CDA implementation guides
and there is an developer version allowing you to extend the project
if you need the other ones let me know and i will update them to oxygen
thanks
sean
Re: how to install MDHT in eclipse [message #1781458 is a reply to message #1781243] Wed, 07 February 2018 07:50 Go to previous messageGo to next message
thanks
sean
Re: how to install MDHT in eclipse [message #1781569 is a reply to message #1781458] Thu, 08 February 2018 14:31 Go to previous messageGo to next message
in fact i'am going to develope a java application who generates document based on CDA and i don't know from where to start , I can not find a step by step documentation , can u please help me , by giving me the right instructions to do ?
Re: how to install MDHT in eclipse [message #1786173 is a reply to message #1781458] Thu, 26 April 2018 08:42 Go to previous messageGo to next message
Dear Sean,
We are creating new content profiles based on the CDA models for the eHealthConnector sourceforge.net/projects/ehealthconnector/ . I was going to use the old design development from sourceforge.net/projects/oht-modeling/files/Releases/Products/Designer/ but just came across this post after reading the whole forum. Now I would be quite interested if you would update the setup file for a desing version so I could use a new one:)
When importing the models now the way is to use this site git.eclipse.org/r/plugins/gitiles/mdht/org.eclipse.mdht/ (which branch should be used?) or still go with the github.com/mdht/mdht & github.com/mdht/mdht-models (again which branch should be used?)
Many thanks in advance and best regards,
Philippe
Re: how to install MDHT in eclipse [message #1801433 is a reply to message #1786173] Fri, 18 January 2019 18:35 Go to previous message
Sean
How is the https://github.com/mdht/mdht-models/blob/volume3/releng/setups/OxygenMDHT.setup used in Eclipse?
Is it imported to an existing Eclipse installation?
Do you use the Eclipse installer application?
Can you provide some instructions? or a link to instructions?
Many thanks,
John
Previous Topic:VDT Summary - Diagnostic Image Report
Next Topic:Careplan - planned procedure Validation error
Current Time: Mon Sep 22 01:08:24 EDT 2025
Powered by FUDForum. Page generated in 0.04074 seconds
