Home » Modeling » TMF (Xtext) » Issue with formatting line breaks
Issue with formatting line breaks [message #1786100] Wed, 25 April 2018 10:17 Go to next message
Hello :)
I am currently trying to apply some formatting rules on my textual model which inserts line breaks after and before each curly bracket. Although this is what I want in general, I need to make an exception for one grammar rule/element.
This is my formatting code:
                 // set indentation inside all curly brackets
		// set line wrap after each left curly bracket
		// set line wrap around each right curly bracket
		for (org.eclipse.xtext.util.Pair<Keyword, Keyword> p : f.findKeywordPairs("{", "}")) {
			c.setIndentationIncrement().after(p.getFirst());
			c.setIndentationDecrement().before(p.getSecond());
			c.setLinewrap().after(p.getFirst());
			c.setLinewrap().around(p.getSecond());
Now let's say I have an element type which I don't want this formatting rule to be applied to. Below is my grammar for that element, where you can see that there is curly bracket and I don't want it to have line break after and before.
WCA returns Modifiable:
	{WCA} name=ID '{'
	override=Override?
	guard=Guard?
	segment=Action
Should I add anything in my formatting code ?
Any help would be appreciated.
Parsa
Re: Issue with formatting line breaks [message #1786101 is a reply to message #1786100] Wed, 25 April 2018 10:38 Go to previous messageGo to next message
you could compare the keywords you get wih the constants in your grammar access.
and use this in a if else
Re: Issue with formatting line breaks [message #1786121 is a reply to message #1786101] Wed, 25 April 2018 15:49 Go to previous messageGo to next message
Thanks Christian for the quick reply.
That is what I don't know actually. the p variable which is my keyword, doesn't have anything that can help me to identify the element type. It just has first and second and I can't seem to find anything from the first and second objects. Ideally, I would like to say the following but I don't know how to get to that:
if (p partof WCA)
Don't format !
else
Do Format !
Could you please give some more details on how to do this ?
Parsa
Re: Issue with formatting line breaks [message #1786123 is a reply to message #1786121] Wed, 25 April 2018 15:59 Go to previous messageGo to next message
The the yourdslgrammar Access (inject it or use the already available)
There should be a getyourifelsestatementaccess
Which should have two open and two closed curly keyword
You can compare with the Ones from the pairs
Re: Issue with formatting line breaks [message #1786124 is a reply to message #1786123] Wed, 25 April 2018 16:08 Go to previous message
Thanks a lot Christian, it works perfectly.
Just for people who might have the same issue as mine, below is the if statement:
			if (!(p.first.equals(f.WCAAccess.leftCurlyBracketKeyword_2) &&
				p.second.equals(f.WCAAccess.rightCurlyBracketKeyword_6))) {
Previous Topic:quickfix support theia/vscode ides
Next Topic:Migrate from AbstractDeclarativeFormatter to AbstractFormatter2
Current Time: Mon Jul 21 02:36:23 EDT 2025
Powered by FUDForum. Page generated in 0.44630 seconds
