I can´t create Relationship edge [message #1785825] |
Fri, 20 April 2018 06:20  |
First, I'm sorry for my bad English. I need to create relationship edges between elements but I can't do this. When I click over the element origin, the console shows this:
ENTRY org.eclipse.ui 4 0 2018-04-20 11:51:30.458
!MESSAGE Unhandled event loop exception
!STACK 0
at org.eclipse.sirius.business.internal.helper.task.ModelOperationToTask.createTask(ModelOperationToTask.java:171)
at org.eclipse.sirius.business.internal.helper.task.ExecuteToolOperationTask.createTask(ExecuteToolOperationTask.java:168)
at org.eclipse.sirius.business.internal.helper.task.ExecuteToolOperationTask.<init>(ExecuteToolOperationTask.java:95)
at org.eclipse.sirius.business.api.helper.task.TaskHelper.buildTaskFromModelOperation(TaskHelper.java:105)
at org.eclipse.sirius.diagram.tools.internal.command.builders.EdgeCreationCommandBuilder.buildCreateEdgeCommandFromTool(EdgeCreationCommandBuilder.java:213)
at org.eclipse.sirius.diagram.tools.internal.command.builders.EdgeCreationCommandBuilder.buildCommand(EdgeCreationCommandBuilder.java:94)
at org.eclipse.sirius.diagram.tools.internal.command.UndoRedoCapableEMFCommandFactory.buildCreateEdgeCommandFromTool(UndoRedoCapableEMFCommandFactory.java:357)
at org.eclipse.sirius.diagram.ui.graphical.edit.policies.SiriusGraphicalNodeEditPolicy.buildCreateEdgeCommand(SiriusGraphicalNodeEditPolicy.java:1109)
at org.eclipse.sirius.diagram.ui.graphical.edit.policies.SiriusGraphicalNodeEditPolicy.buildSiriusConnectionCreationCmd(SiriusGraphicalNodeEditPolicy.java:789)
at org.eclipse.sirius.diagram.ui.graphical.edit.policies.SiriusGraphicalNodeEditPolicy.getConnectionCompleteCommand(SiriusGraphicalNodeEditPolicy.java:748)
at org.eclipse.gef.editpolicies.GraphicalNodeEditPolicy.getCommand(GraphicalNodeEditPolicy.java:130)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.GraphicalNodeEditPolicy.getCommand(GraphicalNodeEditPolicy.java:602)
at org.eclipse.gef.editparts.AbstractEditPart.getCommand(AbstractEditPart.java:502)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$1(GraphicalEditPart.java:1)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart$1.run(GraphicalEditPart.java:482)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.getCommand(GraphicalEditPart.java:477)
at org.eclipse.sirius.diagram.ui.edit.api.part.AbstractDiagramNodeEditPart.getCommand(AbstractDiagramNodeEditPart.java:371)
at org.eclipse.gef.tools.TargetingTool.getCommand(TargetingTool.java:123)
at org.eclipse.gef.tools.AbstractConnectionCreationTool.handleMove(AbstractConnectionCreationTool.java:321)
at org.eclipse.sirius.diagram.ui.tools.internal.palette.ConnectionCreationTool.handleMove(ConnectionCreationTool.java:56)
at org.eclipse.gef.tools.AbstractTool.mouseMove(AbstractTool.java:1182)
at org.eclipse.gef.EditDomain.mouseMove(EditDomain.java:287)
at org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouseMoved(DomainEventDispatcher.java:365)
at org.eclipse.draw2d.LightweightSystem$EventHandler.mouseMove(LightweightSystem.java:543)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:213)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:86)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4428)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4238)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3817)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1039)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:153)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:680)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:594)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:151)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
at org.eclipse.equinox.launcher.Main.main(Main.java:1472)
This message appears ever when i click over the element origin for create the relationship and
when I want to link to the target element.
Some solution?
FUDForum. Page generated in 0.07004 seconds
