Eclipse Won't Open Suddenly (Resolved) [message #1786057] |
Tue, 24 April 2018 23:52  |
Dear kind , gentle, generous, helpful reader,
So I was happily working with an older version of Eclipse (4.4.1) rand easily migrated to 4.7.3 (with JDK 10) and I have a ton of projects that I was using with 4.7.3. Then I installed Intellij Idea 2018.1.1 and I did not even get to creating a single project in IntelliJ when I tried to open my old workspace to migrate some files to intellij (I wanted to use their UML class diagram synchronization design feature among others like analytics and software metrics tools etc.).
When I tried to open my eclipse projects to see my java source files it gave me an error :
An error has occurred see the log file C:\workspace\.metadata\.log
I open the .log file and this is the error I see there (also attached entire log file - though the main error is pasted here )
!SESSION 2018-04-24 23:10:54.245 -----------------------------------------------
eclipse.buildId=4.7.3.M20180330-0640
java.version=10.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.osgi 4 0 2018-04-24 23:11:03.058
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
I looked at the bug report here :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=493761
and I noticed that the eclipse.ini file does have add-modules=ALL-SYSTEM
set (you can check the attached eclipse.ini).
So any help would be appreciated.
BTW my environment variables just has PATH set pointing to jdk 10 (attaching screenshot of the path variable).
Any help would be appreciated.
Sincerely and respectfully, a happy Tuesday to all!
Attachment: log
(Size: 726.60KB, Downloaded 255 times)
Attachment: eclipse.ini
(Size: 0.57KB, Downloaded 288 times)
Attachment: PathVar.PNG
(Size: 20.56KB, Downloaded 370 times)
[Updated on: Wed, 25 April 2018 12:12] by Moderator
FUDForum. Page generated in 0.07033 seconds
