Home » Modeling » M2T (model-to-text transformation) » Obtain the xmi:id using ACCELEO(Obtain the xmi:id using ACCELEO)
Obtain the xmi:id using ACCELEO [message #1786027] Tue, 24 April 2018 06:11 Go to next message
I am transforming the following model, and I do not know how I can get the xmi:id="_RaqRcBM5EeidJK-o_nmT9w" from the uml:Activity. Can you provide me some ideas. Thank you.
<uml:Activity xmi:id="_RaqRcBM5EeidJK-o_nmT9w" name="Software Unit Design Process">
<eAnnotations xmi:type="ecore:EAnnotation" xmi:id="_RarfkBM5EeidJK-o_nmT9w" source="uma_element">
<details xmi:type="ecore:EStringToStringMapEntry" xmi:id="_RarfkRM5EeidJK-o_nmT9w" key="uri" value="uma://_WZ_08BJXEeiXAaw_jOcS-Q#_WZ_08RJXEeiXAaw_jOcS-Q"/>
<details xmi:type="ecore:EStringToStringMapEntry" xmi:id="_RarfkhM5EeidJK-o_nmT9w" key="type" value="Activity"/>
</eAnnotations>
<node xmi:type="uml:ActivityParameterNode" xmi:id="_Rg6qcBM5EeidJK-o_nmT9w" name="Start Software Unit Design Process" outgoing="_VmyToBM5EeidJK-o_nmT9w" incoming="_VJsH8BM5EeidJK-o_nmT9w">
<eAnnotations xmi:type="ecore:EAnnotation" xmi:id="_Rg6qcRM5EeidJK-o_nmT9w" source="uma_element">
<details xmi:type="ecore:EStringToStringMapEntry" xmi:id="_Rg6qchM5EeidJK-o_nmT9w" key="uri" value="uma://_WZ_08BJXEeiXAaw_jOcS-Q#_PV0r4hM5EeidJK-o_nmT9w"/>
<details xmi:type="ecore:EStringToStringMapEntry" xmi:id="_Rg6qcxM5EeidJK-o_nmT9w" key="type" value="Task"/>
</eAnnotations>
</node>
<node xmi:type="uml:ActivityParameterNode" xmi:id="_Rg6qdBM5EeidJK-o_nmT9w" name="Specify software unit design" outgoing="_WC-gYBM5EeidJK-o_nmT9w" incoming="_VmyToBM5EeidJK-o_nmT9w">
<eAnnotations xmi:type="ecore:EAnnotation" xmi:id="_Rg6qdRM5EeidJK-o_nmT9w" source="uma_element">
<details xmi:type="ecore:EStringToStringMapEntry" xmi:id="_Rg6qdhM5EeidJK-o_nmT9w" key="uri" value="uma://_WZ_08BJXEeiXAaw_jOcS-Q#_PV0r4RM5EeidJK-o_nmT9w"/>
<details xmi:type="ecore:EStringToStringMapEntry" xmi:id="_Rg6qdxM5EeidJK-o_nmT9w" key="type" value="Task"/>
</eAnnotations>
</node>
<node xmi:type="uml:ActivityParameterNode" xmi:id="_Rg6qeBM5EeidJK-o_nmT9w" name="Design Software Unit" outgoing="_WfYvkBM5EeidJK-o_nmT9w" incoming="_WC-gYBM5EeidJK-o_nmT9w">
<eAnnotations xmi:type="ecore:EAnnotation" xmi:id="_Rg6qeRM5EeidJK-o_nmT9w" source="uma_element">
<details xmi:type="ecore:EStringToStringMapEntry" xmi:id="_Rg6qehM5EeidJK-o_nmT9w" key="uri" value="uma://_WZ_08BJXEeiXAaw_jOcS-Q#_PV0r4BM5EeidJK-o_nmT9w"/>
<details xmi:type="ecore:EStringToStringMapEntry" xmi:id="_Rg6qexM5EeidJK-o_nmT9w" key="type" value="Task"/>
</eAnnotations>
</node>
<node xmi:type="uml:InitialNode" xmi:id="_SAsWsBM5EeidJK-o_nmT9w" outgoing="_VJsH8BM5EeidJK-o_nmT9w"/>
<node xmi:type="uml:ActivityFinalNode" xmi:id="_UKHhUBM5EeidJK-o_nmT9w" incoming="_WfYvkBM5EeidJK-o_nmT9w"/>
<edge xmi:type="uml:ControlFlow" xmi:id="_VJsH8BM5EeidJK-o_nmT9w" source="_SAsWsBM5EeidJK-o_nmT9w" target="_Rg6qcBM5EeidJK-o_nmT9w"/>
<edge xmi:type="uml:ControlFlow" xmi:id="_VmyToBM5EeidJK-o_nmT9w" source="_Rg6qcBM5EeidJK-o_nmT9w" target="_Rg6qdBM5EeidJK-o_nmT9w"/>
<edge xmi:type="uml:ControlFlow" xmi:id="_WC-gYBM5EeidJK-o_nmT9w" source="_Rg6qdBM5EeidJK-o_nmT9w" target="_Rg6qeBM5EeidJK-o_nmT9w"/>
<edge xmi:type="uml:ControlFlow" xmi:id="_WfYvkBM5EeidJK-o_nmT9w" source="_Rg6qeBM5EeidJK-o_nmT9w" target="_UKHhUBM5EeidJK-o_nmT9w"/>
</uml:Activity>
<notation:Diagram xmi:id="_RavxABM5EeidJK-o_nmT9w" type="AD" element="_RaqRcBM5EeidJK-o_nmT9w" name="Software Unit Design Process" measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_RhNlYBM5EeidJK-o_nmT9w" type="1009" element="_Rg6qcBM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_RhNlZhM5EeidJK-o_nmT9w" type="4008"/>
<styles xmi:type="notation:FontStyle" xmi:id="_RhNlYRM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_RhNlYhM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FillStyle" xmi:id="_RhNlYxM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:LineStyle" xmi:id="_RhNlZBM5EeidJK-o_nmT9w" lineColor="0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_RhNlZRM5EeidJK-o_nmT9w" x="130" y="180"/>
</children>
<children xmi:type="notation:Node" xmi:id="_RhNlZxM5EeidJK-o_nmT9w" type="1009" element="_Rg6qdBM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_RhNlbRM5EeidJK-o_nmT9w" type="4008"/>
<styles xmi:type="notation:FontStyle" xmi:id="_RhNlaBM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_RhNlaRM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FillStyle" xmi:id="_RhNlahM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:LineStyle" xmi:id="_RhNlaxM5EeidJK-o_nmT9w" lineColor="0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_RhNlbBM5EeidJK-o_nmT9w" x="325" y="180"/>
</children>
<children xmi:type="notation:Node" xmi:id="_RhNlbhM5EeidJK-o_nmT9w" type="1009" element="_Rg6qeBM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_RhNldBM5EeidJK-o_nmT9w" type="4008"/>
<styles xmi:type="notation:FontStyle" xmi:id="_RhNlbxM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_RhNlcBM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FillStyle" xmi:id="_RhNlcRM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:LineStyle" xmi:id="_RhNlchM5EeidJK-o_nmT9w" lineColor="0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_RhNlcxM5EeidJK-o_nmT9w" x="495" y="180"/>
</children>
<children xmi:type="notation:Node" xmi:id="_SBFYQBM5EeidJK-o_nmT9w" type="1004" element="_SAsWsBM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_SBF_UBM5EeidJK-o_nmT9w" type="4003">
<layoutConstraint xmi:type="notation:Location" xmi:id="_SBF_URM5EeidJK-o_nmT9w" y="5"/>
</children>
<styles xmi:type="notation:FontStyle" xmi:id="_SBFYQRM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_SBFYQhM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FillStyle" xmi:id="_SBFYQxM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:LineStyle" xmi:id="_SBFYRBM5EeidJK-o_nmT9w" lineColor="0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_SBFYRRM5EeidJK-o_nmT9w" x="86" y="194"/>
</children>
<children xmi:type="notation:Node" xmi:id="_UKHhURM5EeidJK-o_nmT9w" type="1001" element="_UKHhUBM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_UKHhVxM5EeidJK-o_nmT9w" type="4001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_UKHhWBM5EeidJK-o_nmT9w" y="5"/>
</children>
<styles xmi:type="notation:FontStyle" xmi:id="_UKHhUhM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_UKHhUxM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FillStyle" xmi:id="_UKHhVBM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:LineStyle" xmi:id="_UKHhVRM5EeidJK-o_nmT9w" lineColor="0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_UKHhVhM5EeidJK-o_nmT9w" x="630" y="195"/>
</children>
<styles xmi:type="notation:PageStyle" xmi:id="_RavxARM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:GuideStyle" xmi:id="_RavxAhM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:DescriptionStyle" xmi:id="_RavxAxM5EeidJK-o_nmT9w"/>
<edges xmi:type="notation:Edge" xmi:id="_VJsH8RM5EeidJK-o_nmT9w" type="3001" element="_VJsH8BM5EeidJK-o_nmT9w" source="_SBFYQBM5EeidJK-o_nmT9w" target="_RhNlYBM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_VJ148BM5EeidJK-o_nmT9w" type="4012">
<layoutConstraint xmi:type="notation:Location" xmi:id="_VJ148RM5EeidJK-o_nmT9w" y="40"/>
</children>
<styles xmi:type="notation:RoutingStyle" xmi:id="_VJsH8hM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FontStyle" xmi:id="_VJsH8xM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:LineStyle" xmi:id="_VJsH9BM5EeidJK-o_nmT9w" lineColor="0"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_VJsH9RM5EeidJK-o_nmT9w" points="[10, -4, -130, -4]$[148, -24, 8, -24]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_VmyTohM5EeidJK-o_nmT9w" type="3001" element="_VmyToBM5EeidJK-o_nmT9w" source="_RhNlYBM5EeidJK-o_nmT9w" target="_RhNlZxM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_VmyTpxM5EeidJK-o_nmT9w" type="4012">
<layoutConstraint xmi:type="notation:Location" xmi:id="_VmyTqBM5EeidJK-o_nmT9w" y="40"/>
</children>
<styles xmi:type="notation:RoutingStyle" xmi:id="_VmyToxM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FontStyle" xmi:id="_VmyTpBM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:LineStyle" xmi:id="_VmyTpRM5EeidJK-o_nmT9w" lineColor="0"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_VmyTphM5EeidJK-o_nmT9w" points="[86, -8, -108, -8]$[188, -24, -6, -24]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_WC-gYhM5EeidJK-o_nmT9w" type="3001" element="_WC-gYBM5EeidJK-o_nmT9w" source="_RhNlZxM5EeidJK-o_nmT9w" target="_RhNlbhM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_WC-gZxM5EeidJK-o_nmT9w" type="4012">
<layoutConstraint xmi:type="notation:Location" xmi:id="_WC-gaBM5EeidJK-o_nmT9w" y="40"/>
</children>
<styles xmi:type="notation:RoutingStyle" xmi:id="_WC-gYxM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FontStyle" xmi:id="_WC-gZBM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:LineStyle" xmi:id="_WC-gZRM5EeidJK-o_nmT9w" lineColor="0"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_WC-gZhM5EeidJK-o_nmT9w" points="[71, -9, -96, -9]$[115, -9, -52, -9]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_WfZ9sBM5EeidJK-o_nmT9w" type="3001" element="_WfYvkBM5EeidJK-o_nmT9w" source="_RhNlbhM5EeidJK-o_nmT9w" target="_UKHhURM5EeidJK-o_nmT9w">
<children xmi:type="notation:Node" xmi:id="_WfZ9tRM5EeidJK-o_nmT9w" type="4012">
<layoutConstraint xmi:type="notation:Location" xmi:id="_WfZ9thM5EeidJK-o_nmT9w" y="40"/>
</children>
<styles xmi:type="notation:RoutingStyle" xmi:id="_WfZ9sRM5EeidJK-o_nmT9w"/>
<styles xmi:type="notation:FontStyle" xmi:id="_WfZ9shM5EeidJK-o_nmT9w" fontName="Arial" fontHeight="8"/>
<styles xmi:type="notation:LineStyle" xmi:id="_WfZ9sxM5EeidJK-o_nmT9w" lineColor="0"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_WfZ9tBM5EeidJK-o_nmT9w" points="[52, -4, -85, 0]$[133, -8, -4, -4]"/>
<targetAnchor xmi:type="notation:IdentityAnchor" xmi:id="_WfdoEBM5EeidJK-o_nmT9w" id="(0.16666666666666666,0.20833333333333334)"/>
</edges>
</notation:Diagram>
</xmi:XMI>
Re: Obtain the xmi:id using ACCELEO [message #1786143 is a reply to message #1786027] Thu, 26 April 2018 02:42 Go to previous messageGo to next message
The xmi:id is an often unstable XMI serialization artefact that might not exist with a non-XMI representation such as a database. The xmi:id is therefore intentionally not available within pure modelling tools. If you really need it you can invoke a Java helper. However I strongly recommend that you rethink your perceived need to access the xmi:id.
Ed Willink
Re: Obtain the xmi:id using ACCELEO [message #1786300 is a reply to message #1786143] Mon, 30 April 2018 08:38 Go to previous messageGo to next message
Thank you very much... I would like to use the java helper you mentioned... How can I do this.
Julieth
Re: Obtain the xmi:id using ACCELEO [message #1786302 is a reply to message #1786300] Mon, 30 April 2018 09:11 Go to previous message
I'm sorry. If you cannot figure out how to use invoke in Acceleo and getEObjectID in EMF, then it is definitely the wrong approach for you.
Ed Willink
Previous Topic:Acceleo transformation
Next Topic:Acceleo transformation
Current Time: Sun Jul 20 21:16:16 EDT 2025
Powered by FUDForum. Page generated in 0.06702 seconds
